Cylinder Wall
Well finally got around to working on the blown head gasket. It ended up blowing in the number 1 cylinder. I have the head off right now and am getting it checked for warpage. My question has to do with the #1 cylinder. There are no scuff marks moving up and down however as you will see in the picture below the walls almost appear to be bleached or cleaned. Not sure if this is the right termonalogy or not but owell. I have ran my finger nail along the whole thing and cant get it to catch on anything I have just never seen anything like this. My question is do you believe it would be ok to leave this cylinder like this or should it be honed? Really hoping it's ok as I dont have a engine stand or hoist at the moment. This is a 97 with 218 miles on it. Thanks for the advice.
Adding to what Beno has said, what is your location? A local cruiserhead might be around the corner to take a peak since you have it torn down this far you want to do it right.
When I get back home I will post a more clear picture. The location is Lubbock, Tx
Well I hope these pictures are more clear. Like I said I cant tell if these walls are like this becuase of sitting with the head gasket blown for a month or whether some real damage was done. I never had a knock or anything before the head gasket. Thanks for yalls help.
At a minimum, being in the position you are, I would do a hone on all of the cylinders and new rings.
Not sure how far you were planning on going but at that many miles, that's what I would do.
Rgds...
Is that scuffing and what causes it, broken rings, piston slap?? IDK.
IMO If you have scoring like this picture, then I think you would need to have the cylinder cleaned up (bored out slightly to clean out the vertical scoring and then honed). If you only have the original honing marks (crosshatch pattern) then I think you would be okay to leave it as is.
The white hazy look on your cylinder wall is from the water/coolant "washing" the cylinder. If you had driven the vehicle with the blown head gasket for a longer amount of time, then you would probably end up with vertical scoring of the cylinder wall and that would necessitate repairs to the cylinder wall.
IMO, I would not hone the cylinder, I would put it back together and run it. Later on, if you're planning a rebuild, then you can hone/bore the cylinders. :)
that piston top look like it has been steam cleaned by coolant getting into the cylinder. when my hg went at #1 cylinder it still had a the carbon on it.
with the fogging on the wall and the pristine piston i'd be most concerned that lots of coolant leaked into the sump. did you drain it? any sign of contamination?
Robbie needs to look at this. That cylinder wall does not look good to me.
+1 what Chewbacca said. Number 1 cylinder typically has the most wear in these engines as it is closest to the water pump. Clean up the HG surface and put it back together.
Thanks for all the replies guys. Yes I did drain the oil and there was no sign of coolant which surprised me. While trying to diagnose a head gasket failure I never had water droplets or milkshake on the dipstick and never had anything under the cap. We also did a sniffer test that came back negative. We finally noticed while doing a compression test that coolant was dripping out from where the front exhaust manifold connects to the exhaust flange or pipe.
Nawilla: post up what else you find or end up doing
Depending on how the rest of the truck is (structurally and such) I'd just run it as-is. If you have an absolute cherry rig it might be worth pulling that piston to hone it but regardless you'll still likely get another 100k+ after installing just the new HG.
I'll add my vote to the "run it like it is" crowd. If your going to take the bottom end out, then I would pony up for a full rebuild. If your breaking it down that far, its not much more of a headache to do it all.
X3, run it. Hard to be sure from the pix, but it looks like the factory crosshatch is still viable, if so it's just a color thing, very little wear. No way would I hone it, unless new rings were also being installed.
Well guys decided to just run it how it is. I believe this is caused from the piston just sitting in the same spot for a while becuase while cleaning the piston and walls before putting the head back on I noticed the same ring although just one not several in two other pistons. This truck is just a weekend and hunting vehicle not a normal driver so if something happens I will just pull the whole drivetrain though I'm hoping that does not happen.
Update on the Progress.
Well while waiting to the the head back I finished up my front axle rebuild (I think dirty is a understatement and I now HATE cone washers).
Got the head back from the machine shop where they milled it flat cleaned it and did a valve job, also had both intakes dipped and cleaned, and then threw some paint on the valve cover. Rebuilt the starter, did a brush kit on the alt, and replaced the thermo and fuel filter. I bolted everything on to the head that I could while it was out of the truck (injectors, fuel rail, intake manifold back together, egr system) and got it bolted back to the block tonight. Tomarrow I will put the cams back in and hook everything up below the intake. I have a leak at the oil pump so after the cams are on I will prob take out the crank bolt and replace both of those seals before I move forward with putting the rest back together. I'm waiting for a starter contact from the dealer since they gave me two of the same one and that wont be in till Tuesday so I hope to have the truck started then. Wish me luck
Vertical Scoring
Found this in my No.1 cylinder when doing a head gasket r&r.
Please don't tell me I need to hone and re-ring, let me just slap this back together and be blissfully unaware of any further damage I could do to my 1FZ.
Honing/boring and new pistons/rings will add a lot of additional life to an engine but i'm sure it will still function even with some imperfections. As others have said, you have to decide what you want to do with the motor. If you need it to run another 200k, hone it now. If it's just a weekend toy, whatever.
Is this kind of cylinder wear indicative of broken or excessively worn piston rings?
