While doing some routine maintenance yesterday, I noticed that my outer CV boots were both split. I have a 460 mile roadtrip planned for next weekend, so I have to fix them NOW.
Manual or automatic hubs?
What kind of wheeler is it?
What kind of wrencher are you?
I talked to a mechanic buddy about it this morning and he recommended replacing the joints and everything while I was in there, since I don't know exactly how long they've been shot and I mostly drive on dirt. He said it would probably be a lot easier as well.
Considering how much wear is on them. FYI they DO NOT have the miles you have on the odometer
I need some educated guesses on:
-how long to expect it to take (I've read on the web, up to 8 hours)
-what parts I should replace (any good kits?)
-what parts I'm going to break, getting them off
-if I need any special tools
I'm also considering making the switch to manual hubs since I'll have them off anyway.
Any thoughts?
My life, being obligated to "on the cheap" I would consider
CV Grease
Break parts cleaner if I could not find a friend with parts cleaner basin first.
spare boots and I think the bands come with them and you can borrow a bander (the thing that simultaneously pulls, crimps and cuts the boot band)
#1: Personally I would pull the hub dial...FLANGE
and remove the axle retainer bolt and washer that will be staring you in the face once you pull the dial.....just the dial!
#2: Then (and this will be hard) remove the flange bolts from the inner joint.
The birfield will be a
to clear the studs so I would consider trying to tap the studs out first.
**NOTE** you can push the grease seal out of the back of the birfild if you try to clear the studs, the axle will push it out from the inside while you are trying to clear it from the studs**
#3: Rotate the diff stub axle flanges where the cut outs will help the Birfild pass it, then once you've got the axle shaft where it will pass the flange it should allow for the shaft to come right out. I would not pull the upper or lower BJ (but thats just me) you can either pay or do what you feel is right.
If you need space since its been a wile since I done it Undo the Diff cover bolt and jack up the diff a little, that should net enough room to pass the shaft.
WARNING: the above is what I would do I am both lazy and do not pay for someone else's labor.
If I had ADD I would strongly consider replacing the shafts entirely
Manual and I would,
depending on budget and time clean the joint replace the grease and all or just the broken boots....depends
Now would be a good time to consider
this to
my above is based on: if you want to, or can do, and if you have some tools.
Dang it! always see it last! ;p
Any thoughts?
Do this ASAP!
