If you have an Engineer friend or are capable yourself calculate the cross section inertia of the original vs your proposed design. Make yours stronger and then you can cut the frame and have less compromise in your design. That is what i would do.
I vote for a cantelever swing link dealie that compresses a coil over that is mounted horizontally under the cargo floor fi style. Thats all I got lol.
D
Random thought... have you considered airbags? They'd more or less work with the bucket's you've got, with positioning shackles radical travel is possible, and the sky's the limit for load capacity.
Not to mention adjustable ride height and possibly even forced articulation with a compressor.
Love all of the ideas, though I think it's contributing to my ADD.
How's this for slightly insane (and expensive) - what about combining the Firestone air springs under the frame with dual-rate emulsion coilovers (emulsion because they're way cheaper)? That way I'd get the stability and load carrying capacity of the air springs on the road, but could air them down and use the coils on the trail. I could use the air springs to force articulate in hard spots. Also, I'd have redundancy if an air spring popped - I could just run on the coils.
I'm also wondering about putting air spring helpers inbetween the leaf and the frame on the front SOA in place of bump stops. Better ride, prevent sag, and possibly forced articulation?
I'd not run coil overs and air. Rigs have been running air suspensions for at least a decade... If in doubt, carry a spare air bag.
On the front, I can see an advantage. Some day, I'd like to add them to my rear SUA to combat sag and improve ride. I've got plenty of rearched leaves, but they struggle with the 2500+ lbs I've got on the rear axle.
You don't need to cut the frame to fit coil springs... see my build thread in the Hardcore section (https://forum.ih8mud.com/hardcore-corner/618203-project-resurrection-v1-1-a.html) for reference. Rear double triangulated 4 link with front coils from a 6 cyl Jeep TJ. Packaging is tight with a cruiser width axle, but the suspension cycles without the tires rubbing the springs or frame. From the looks of it, you have your rear axle sitting in roughly the same location as I do... pushed back ~12.5".
80 or 75 series coils would obviously work if you want to stick with Toyota, but TJ coils are cheap and spares can be had in just about every junk yard and they're considerable smaller in diameter than LC coils so packaging is more in your favor. You can also get lift springs in smaller increments for the TJ's for much less money than LC's.
Why does it look like you have more space between your lower spring bucket and the chassis than I do?
Those springs look very flexy. Are you concerned about load capacity at all?
I'm curious why you rebuilt the back chassis - what you put in looks pretty much the same as stock except for the crossbracing, except it is much stronger. Why not just box the stock chassis and reinforce the rear most cross member / bumper mount?
