My 2f pops thew the carb when cold, i have to use choke to control it. wams up after 5mins or so and when warm no more poping. I have 30 psi in #1 cyl i thik a bad valve ceck comperetion and let it warm up se if it stops poping.
Newrider said:When it was running before it was still backfiring some..but it idled perfectly. Literally all I did was pull the carb. Fix the mounting studs, and put the carb back on. Any ideas?
Pin_Head said:Maybe something wierd happened to the carb when you had it off, like a piece of dirt got loose and plugged the fuel circuit. Pop the top cover and take a peek to see if there is any junk in the bowl.
I made sure nothing went it there because I put duct tape on there before doing anything. I may try that gag method with the carb to see if I can make it suck anything out. I dunno though...it just doesn't seem like the carb has a problem...its seems like something else...but I just can't seem to figure it out..unless it is indeed vacuum..but I've checked them so many times
ryan
Newrider said:I dunno though...it just doesn't seem like the carb has a problem...its seems like something else...but I just can't seem to figure it out..
ryan
IDave said:When it was backfiring before, was it through the carb or through the exhaust?
DHONDAGOD said:does this thing have points and condensor? does the dist shaft have any slop in it?
chris![]()
julio71fj40 said:Just a thought. Does your ignition system use points? I always had problems with my points sticking and the result was often backfiring. I have since changed to a electronic ignition (dizzy) after reading posts on this site. I know you were working on the carb, but your distributor may be acting up. I may be way off though. It is worth checking since it is easier than pulling off your carb and junk.
But I'll post up later today and tell ya'll the info. One question: If it does indeed become that the brake booster vacuum line is leaking...can I just plug both hose fittings and be done with that for now? I know my brakes wouldn't be as good but I think I could live with that for the time being..
