Cute Story
Orlando, Fl
So I installed helicoils on the intake manifold where the carb base hooks up like I had posted on before. I got it sealed and everything and didn't touch the adjustments on the carb when I pulled it out. I get everything back on and go to crank...the thing won't idle and is STILL backfiring out of the intake and exhaust. It became worse that it was before I sealed the base of the carb today. I have checked the timing multiple times and it is right where it needs to be. I replaced the one vacuum line I have except for the one going to the brake booster...but it looks pretty new. Can anyone give me a run through of things to check or a possible solution to my problem?? I'm suppose to take this rig on a road trip on Friday with Sandrider and I'm really stressin out. I appreciate it so much...ya'll have helped me tremedously in the past...thanks again!
Also, I'm not sure if the carb is adjusted correctly..but it was correct before hand...because it idled great but it still backfired some...I though that was due to the leaking carb base. Does anyone know the starting positions for my carb...a stock 72 Aisan??? I have 3 idle adjustment screws..one on the butterfly valve, one on the base of the idle control rod, and one the normal idle control screw. As well as the idle/mixture obviously...Thank you...I know its a lot but I figure the more info the more ya'll can figure out whats going on and what I have done
//newrider
I'm going to post a pic of my carb today sometime...
Sounds like you may have something going on besides carb adjustments.
Backfiring thru the carb could be caused by, among other things, incorrect firing order, intake valves sticking open, the 180-degree-off timing thing (engine timing, not ignition timing), etc.
Backfiring thru the exhaust (it's not really a backfire) is probably the ignition of unburned fuel in the exhaust system. It's usually accompanied by some very smelly exhaust due to the presence of unburned hydrocarbons. Unburned fuel mixture can get in the exhaust system by incorrect firing order and engine timing, as noted above. But it's also sometimes caused by weak spark, by vacuum leaks in the intake system. And I guess it could possibly be caused by lean carb adjustment, but I've never seen this. Irononically, the vacuum leaks cause exhaust "backfire" because the fuel mixture isn't rich enough to ignite in the cylinder but instead collects in the exhaust system until there's enough there to light up.
I got ya....But I know the firing order is correct...and I know that the timing is correct as well. I just can't figure out where I would have another carb leak. Anybody else???
How are you sure you're not 180 degrees out on the timing? It is EASY to do.
I guess I can't say that I'm 100% sure that I'm not...but I was 360 degrees off and we fixed that....so that is why I guess the timing is where it should be. How can I check?? I put it on TDC and then adjusted the ball to the arrow. I also know the plug wires are in the order of 153624.
Put the arrow on the BB in the timing window. Look at the distributor cap and note where the #1 plug wire socket is. Take the cap off of the distributor. Make sure that the rotor is pointing to the #1 plug wire socket.
Then, to be absolutely sure, pop off the valve cover and make sure that the 1st and 2nd valves are in the closed or "up" position. This corresponds to the pushrods for those valves being in the relaxed, or "down", position.
Then you will know.
I checked the timing again. It is correct, not the 180 degrees off. I've sprayed around the intake manifold below the base of the carb and it isn't leaking. I have checked the gaps on the plugs, all are fine. The idle adjustments on the carb seem do nothing. I'm sure I have the firing order correct. The idle solenoid is working..it clicks when the ignition turns. It was running great before I took the carb off to instal the helicoils..and now it is backfiring and will not let itself idle. the backfiring is out of the intake and exhaust. I pretty much clueless as to what is going on... ummm...any suggestions?
//newrider
bump
If I had your problem, and at times I have, I'd still turn the distributor around 180 degrees just to see what happens.
The seemingly obvious thing is that you didn't get something right when you put it back together if it ran great before and it runs like crap after.
I little more detail about when it runs poorly and under what circumstances it backfires might help. Try adjusting the idle speed screw to see what the minimum speed it will run at.
What happens when you crack the bottom of the intake manifold just underneath the carb? Just wondering if these would be the symptoms?
pinhead...what it does is at low rpms it is backfiring like crazy out of the carb and exhaust...it stalls itself. At the high rpms with the choke 3/4 out, it doesn't seem to be backfiring. I have tried messing with all the adjustment screws on the carb and they don't seem like they do much. I can understand that if it WERE NOT backfiring why it wouldn't idle...the carb probably isn't adjusted right. But IT IS backfiring and I just don't seem to understand what is making it do so. When it was running before it was still backfiring some..but it idled perfectly. I don't get why when sealing the carb better (and I know its not leaking now due to the carb/choke cleaner I sprayed) it runs worse. Literally all I did was pull the carb. Fix the mounting studs, and put the carb back on. Any ideas?
anyone?
bump
A small experiment.
Start engine and pull the brake booster vacuum line off to create a large vacuum leak. Report back if the engine ran any better or worse.
will do
