Custom winch bumper w/pics
Indiana
I finally finished my bumper it took a while too many things got in the way.It is made of 1/4 inch flat plate.I started bu making it in 3 main parts.Them i used 1/2 inch flat for the frame mounts and welded the center section to that.Then i fitted the 2 outer section andwelded them on.Next i welded the uprights on and the sch. 40 pipe for the bull bars.The bumper had gotten a lot of rust so i had it sand blasted and put on 1 coat of por-15 and 2 coats of Durabak.It weighs about 150 lbs.I would like to have used 3/16 but did have it.It lowered the front an 1 1/4 inchs.Next is the rear bumper and a lift.
here they are
pics
My back hurts just looking at it......;)
I pitty whatever you run into now. Add a winch and you are going to need the heaviest front springs available.
Is that a rubber pad on the end of the wing?
Stay away from the MRI side of the hospital:flipoff2: ...when steel prices rise you will be king...nice work!
