the new unit has no working speedo, and instead of sourcing an oem electronic one to work with the lexus transmission i decided to do up a custom unit. i have the extra parts from a defunct uhaul toyota 1 ton and all the dakota digital gauges i need but the speedometer and fuel level.
pulled the cluster out of the 1 ton and gutted it. removed all the plastic dividers in it with a rotozip (highly recommended, it's like a dremel on steroids and not nearly as clumsy as it looks). it appears to be made out of abs plastic, so i got a 12"x24"x1/8" sheet of textured abs. a fluorescent hot pink sharpie seems to show up decently on black abs. scribed it out with an exacto knife for good measure (it's backwards because i'm plotting and cutting from the back side of it). the top corners appear to be an irregular curve, so i'll have to shape them to fit by hand with a file.
it should plop right in over top of the original cluster face, remove the parts of the original that interfere, abs cement in place, and done step one.
got the basics plotted out, ready to be cut:
more later on...
more later on...
