custom exhaust
I decided that it was time for an upgrade on my factory exhaust under my 1994 land cruiser. The biggest issue that I wanted to resolve was the low hanging side by side catalytic converters. I also wanted to replace the rest of the exhaust with 2.5" pipe and put on a less restrictive muffler. I took the cruiser over to a local exhaust shop that I've had work on several of my trucks in the past. We put it up on the lift and came up with a plan. We decided to replace the dual cats with a single cat that has 2 inlets and 1 outlet. The particular cat that was used is actually designed to fit a dodge ram. Behind that, I had him run 2.5" pipe and a flowmaster 40 series muffler.
So the result is a single cat that sits flush with the frame rail along with a noticeable increase in power above 2500 rpm and of course the nice low rumble of the flowmaster. I'll post up some before and after pictures as soon as I get a chance.
I did something similar on my 91. unfortunately I still have my low hanging factory cats but as soon as I rip them off I'll get something better. An inline 6 sounds great with a flowmaster, doesn't it?
I popped a seam on my factory muffler yesterday on the way home from work. Now I'm considering replacing everything from the header back. I'm going to probobly go with a high flow cat and 2.5" high-pass muffler, with a slightly different exhaust tip exit point.
How much did the whole job end up costing? Parts & labor?
For the cat, muffler, tubing, exhaust hangers, and labor it was about $500. Not too bad considering I would have spent that much on 2 factory replacement cats.
Did you replace or remove the rear resonator?
Either way, how does it sound besides the good rumble? I like the rumble, but I'm concerned about the exhaust drone / sound pressure at highway speeds.
I'm going back and forth between keeping the resonator or cutting it off and trying it without. If I do cut it off, I guess I'd be ready to put something similar back in it's place if it's too noisy.
...soon as I finish Project "dead-in-the-driveway", I'll move back to the exhaust project in the '95.
When I decided to go with the flowmaster, I was concerned about it being too loud for the highway. I figured that I would give it a try and make changes if neccesary. I just just went with a muffler and no resonator. After driving it for a few days around town and on the highway, I can honestly say that it is no louder cruising on the highway than the factory exhaust was (at least not from inside the cruiser, I don't know what it sounds like to all the people I'm blowing past in the slow lane). It's louder during acceleration and under heavy load, but at cruising speed it sounds no different than it did before. Even my wife agrees with me on that, which is good because she drives it mostly. It's no where near as loud as a V8 with dual 3" pipes. In my opinion it sounds perfect and I won't be adding a resonator.
Nice.
Make & model of that duel inlet cat for future reference??
my set-up
I did a high-flow single cat & a Hush-power by magnaflow this past fall... hush-power now a lil too loud for me after it has broken in... used all the normal/OEM piping... no mods to that stuff... much better clearance though with these pieces...
and now the pictures
before:
You will get a whistle by removing the resonator. I had to remove mine when I installed my Hanna rear bumper and at two different spots on the RPM's you will get a whistle. Basically when you step into it. While cruising at Hwy or City speeds your can find a good sweet spot where you will not get a whistle. I am considering adding a down tube to maybe eliminate the whistle or at least tame it a bit.
Yeah, I've heard that before and that's my concern. Mine is supercharged and it whistles now on acceleration with the stock set up, I want to get rid of that. I wonder if just an 'expansion chamber' style resonator would get rid of it?
BTW, what do you mean by a 'downtube'? Are you referring to tail pipe configuration?
