TURN UP THE FUEL! at least 1.5 turns. And put hose clamps on your vacuum hoses on injector pump to throttle body or else your engine will run away on you. TRUST ME!!!
Did you disconnect your waste gate? 20 psi is pretty high for a stock waste gate setup. But if your egt's a cool. Then just go with it. How are you liking it?
Hah. That is a great question. I honestly can't give an exact answer. If yiu dyno tuned it for peak torque to say 2200 rpm you would be able to get an idea of how much but short if that it's a lot of guess work. The hokey stamp marks are grossly inaccurate and if you spill time retard it that would be accurate but by how much? I've searched for this answer for years. If I had endless time I would design a device to make micro adjustments to the pump position in real time while pulling a hill or something and see where you got lowest boost and lowest egts. I think where those two meet your timing is well matched. Someone should do that now that I think of it. Sounds neat.
Happy new year!
g
