cusred fj40
courtenay British Columbia
cursed fj40
Hey everyone
landcruisers rule and this board rocks :D so I am having troubles with my cruiser it seems to be cursed.
after getting a whack load of parts from various landcruisers I managed to piece together a pretty nice 71 fj40. I had a 2f with the orignal drivetrain , that motor got wrecked cuz it was sitting for so long and the fuel pump went bad. not knowing this after running it for a few hours it pooched right out , there was so much gas in the engine oil it ruined the bearings and siezed the motor.
so with all the parts i got, there was the bellhousing for the lc 4spd to a small block. so I got a 350 to put in out of a 85 k20 burban. and it turned out to be a 94 targetmaster goodwrench 350, so I tossed a nice alum intake and some block hugger hedders along with a quadrajet. now after running this one for a while it seems that there is gas in the oil. :eek: :eek:
Since I wrecked a 2f this way i decided i wanted to save this motor , so i went and got a new fuel pump. even after that and an oil change ther was gas in the oil after running for a few hours. so i replace the pcv valve and tried a different carb that was kicking around and same thing gas in the oil , am I just unlucky?
so I am starting to think this is bad luck and I just have two crappy carbs or maybee I am hooking them up wrong or something, one of my freinds suggested that the float bowl plugs were leaking down into the manifold and seeping through the rings into the oil is this likely?? any suggetsions?
im probably gonna end up getting a rebuilt quadrajet
How do you guys hook up your quadrajets, like the vacume hoses and stuff
anyone have any ideas of what might be going on??
thanks in advance :beer:
Are the bolts for the fuel pump the right length? Don't know if it would effect your issue, but when I put a crate motor in, I used too short of bolts for the fuel pump, and it leaked oil like crazy out the bolt holes.
Yeah I have the right length bolts. I used original bolts from another smallblock
Has any one else ever had a problem with gas getting into the oil??
well I am a cheep ass so it a used carb from the wrecker I pulled it off myself. it was on a 85 vandura it didnt look too bad! but why would that make it a bad carb. I hav tried 4 differnt quadrajets and had different results with each carb. would it be possible that a new fuel pump would have too much pressure like a defect or something? cus the hose was pressurized when I went to disconnect it, as soon as I loosend the hose clamp it was squirting out pretty fast and I dont think thats normal. that might also cause the gas to leak out after the engine is turned off??
I need to fix this so I can get the cruiser on the road
I just experienced a q-jet that was leaking bad and overfueling the engine. Rebuilt it many times playing with horne torque, float level, etc. Turns out the brand new fuel pump was putting out 11 psi and I was told 5 psi is correct for q-jet. I installed an in-line pressure gauge to test it ($15-30) and then installed a pressure regulator ($15-35) to being it down to 5. No more problem!! Also sealed the casting plugs during the many rebuilds so that may have helped somewhere along the way. BTW, Holley makes a nice regulator for ~35 bucks which is what I actually used. The 15 dollar one can be found at any parts store but I'm over using cheap crappy parts... like the fuel pump.
I had a wierd feeling about the fuel pump over pressureizing
would the pump for a 307 with a 2barrel rochester feed the fuel that a quadrajet needs on a 350? cuz I have one kicking around
anyone got a good diagram on how to hook up a qjet hose and such, just so I can be sure I have it right?
Do goggle search for your carb. I found the entire shop manual on line for my Qjet.
Good luck.
JB
I decided to go out and buy a new fuel pump (26$) and then an oil change and that seemed to have fixed my problem ( gas smell in oil) but thanks all for you tips on what to do
this board rules IH8MUD! :beer: :beer:
