Cryogenic Birfieds
Cottonwood, Az.
I recently found out there's a local guy who does cryogenic freezing of all kinds of stuff, car parts, gun barrels, ect. I know that Longfield uses the cryo process in the production of their Longfield Super birfields and inners. Does anyone think there's much strength to be gained by just having a plain set of birf's cryo'ed?
IMO, you'll get some gain, but the added material in the ring is really the bigger strength adder...
I had great luck with my first set of Longs....3 year old cryo'd/ringed versions from stock used birfs...but did finally junk one this year. Updated to the new 4340 models and don't expect any more breakage...
Lots of new Cruiser toys coming out soon, Marlin is working on a new knuckle for minis/Cruisers that uses 6 studs for the steering arm along with more beef....
The main process for treating stock Birfields is called annealing or drawing. The trade off is hardness for better toughness (ductility and resistance to impact ). The teated stock Birfs wore faster, but didn't break as easily. I don't know if it is the same for the new Super ones, but I would guess it is. No reason to have a durable bell if is is going to crack.
You want to freeze them you can come over and drop them in my LN2 tank and watch them boil. Kids love playing with it too.
bestout there is the 4340 30spline...only thing I don't like is you can't trade "stock" parts back in the VERY rare change you do break....I run their 4340 birf with the stock 27-spline inner.
The knuckles will be in testing soon, Chris Geiger has had them posted on PBB in the mini corner for a few days...
The info I gathered on Cryoing Toyota birfs was not all that positive. Supposedly, Toyota already hardened the birfs so much for longevity, that they almost become more brittle when you cryo them. Not saying they are weaker, just that you trade the extra strength gained from the cryo process for some extra brittleness. That is why many of the aftermarket birfs are softer and wear faster, but stronger. The guy that know the most is 66cjdean on POR...he did all of my cryo work and was very straight-forward.
Yes, cryo freezing helps any high alloy steel. It realigns the molecules and makes it tougher and more wear resistant. It does not make it SOFTER! We do heat treat the old style Longs, it does make it a little softer to keep the brittleness down and keep it from exploding. Then we cryo freeze them afterwords. The new 4340 chromoly Longs with 300M race are a much harder and stonger material to begin with for much longer wearabilty.
We also do ring and pinions the same way with great success. :bounce:
correct
the new birfs are actually 300M stars and 4340 bells....
from a compatibility standpoint, the only "oddballs" in the bunch are the newest 30-spline stuff....ALL the other options (newfield, bellfield, early longfield, stock mini and cruiser, stock inner, pig inner, 27-spline inner) are interchangable.
