Cruiser shower
Gallons per minute.
Thats all.
They both work on the same principal. The system I built will flow just as good or better than your home shower. Also you can use it for more things than taking a shower like washing pots and pans, connect a hose to it and you could wash your cruiser with hot water. Plus the heat exchanger is pretty efficient at transfering heat.
One change I would probably make is, no hot and cold water knobs. Just hot. Last time I used it in a cold stream I basically had the hot almost all the way open and the temp was just perfect.
Personally if I wasn't mech inclined I would buy Kurts system it has proven to work well.
