Cruise Control Failure
Los Angeles
I have 92 FJ80. I did check the prior threads regarding this issue, and so I checked the brake light switch, brake pedals, brake lights, and parking brake switch and all are functioning. CC switch does light up( does not blink) and remains lit as i try to engage the cruise control, repeatedly but it does not engage. rarely tilt the steering. checked the actuator, stroked 8-10 times, sprayed CRC electric parts cleaner on it, still does not work.
I noticed that there was a lot of play on the cable that leads to the pedal, still tryig to figure out how to remove all that play. I read about this transducer near the transfer case may be the possible culprit?
My bet is the sensor mounted in series in the speedo cable, right at the transfer case, the item you are refering to as a transducer.
88261-60010, list $122.49
D-
Hay Thanks cruiserdan!
I was about to take the actuator apart, i saw a pix of it in a prior thread, good thing i haven't done that, So, how do you replace/install the transducer?
Un-screw the speedo cable from the outer end, un-screw the sender from the sleeve in the transfer case, un-plug the wire and toss it over your shoulder......:D
There is a whole proceedure in the FSM that will pin down the cause. If it does point to the speed sensor there is a proceedure to electricaly test the speed sensor as well.
If you do find out it is the speed sensor give Dan a call. The smart shopper price for this product was about $70 less than my local dealer charged me.
Good luck.
If you don't have a FSM I'll post the proceedure to test the curcuits, its real easy and all done from the front seat.
S
Good luck.
S
I know this is an ancient thread, but my cruise acts the same except for setting once in a while. I would love that procedure you talked about.
let's bring this back! I've tried everything except the transducer, but mines a 96.
Cable is tight enough.
CC light comes on but nothing actuates.
Cruise control has a very sophisticated diagnostics mode. Easy/fun to do, and almost 100% guaranteed to isolate the problem. See the "cruise control" section of the FSM.
Curtis
Dang, I knew you'd say that. I don't have the FSM yet. I'm waiting on it to get here... ugh.
some precedures look like they might work, others do not.
I'll try them.
I wonder if it's got something to do with the CEL code I got, P1780, Park/Nuetral Switch that I'm still having issues with. I'll try clearing the code and checking the cruise while it's cleared.
This is the one for '96
Cruise Diag 96.webp​
What am I missing, I just took the laptop out there and tried this and got nothing like what it describes the CRUISE light didn't blink...
I turn the ignition to ON and do the 1 - 3 steps, but all I get is the CRUISE light on, no blinks, just on. Nothing else happens. This is step 5? what are the previous steps? How do I perform this if I am infact doing it incorrectly?
You did steps 1, a, and b from the "Hint" section?
That's what puts it in diagnostics mode.
Curtis
tried step 4, a and b and it worked, but 1 through 3 does not by just having the ignition on but not cranked.
OK, so for some reason I did the sequence correctly and they all seem to work with exception of the brake pedal press. Nothing happens when I press the brake pedal...
So how does i check that circuit?
Thank for info on testing. My CC is random, it seems once I turn it on and set it, it is fine. However if I brake, the light remains like expected, but it will I wont be able to set again. Until I completley give up, park in the driveway and let sit for a day LOL, ok little exag. but basiscally have to turn off the car off and let rest for a bit.
I'll try the above and see what the results are.
