Cruise Control Behavior
Tulsa, OK
Website
www.cardomain.com
I noticed this same issue on my `91 80 and now on the `97 lex. When cruise control is engaged and you start climbing a hill, the tranny eventually kicks down and jumps the R's to around 3K.
After you crest the hill and start descinding, the tranny still stays "kicked down". I've had this happen on several occassions and eventually just disengaged the system. I realize it should take a moment to kick back up a gear but I've waited for what seems like an eternity, meanwhile, winding out at 3K. Normal, or is there some sort of adjustment that can be done?
I may experiment again and see just how long, or if, the tranny will kick back up. Anyone have similar experiences?
mine also will not up shift after that same scenario. But in reality, you should disengage the cruise control before such a hill because your foot is smarter than the computer and you can feather the pedal to keep it where you want. I turn overdrive off when driving up long hills.
If you have the ECT or PWR button engaged the tranny stays 'kicked up' for longer periods of time.
Mine always upshifts back to 4th eventually, but it often takes a looooong time.
What I usually do is manually shift the lever to 3rd at the base of the hill (keeping the CC engaged) and then keep the speed up with my foot. Then at the top of the hill, shift back to 4th. For whatever reason, the CC does *not* keep it in 3rd under this scenario. :meh:
Curtis
Bumping this thread back into action, as I have the same problem with both my '92 & '94 cruise controls. Has anyone tried adjusting the cruise control in any way to make it less aggressive at down-shifting? Personally, I'd be happy if it didn't down-shift at all and simply shut off if it couldn't maintain the set speed in the gear it was already in.
I almost shat my pants the first time this happened but have gotten used to it now. Mine upshifts when the van crests the hill.
D
It's a Toyota cruise control thing. ........
While it may be a common Toyota CC problem, I believe it's also possible that increased tire diameter makes the problem worse. When cresting a grade and transitioning to either level or downhill, the CC is looking at throttle input, as well as speed. It's programmed to upshift at the appropriate point to avoid seeking (jumping back & forth, 3-4). If, because of increased tire diameter, more throttle is needed to maintain speed than the CC has determined to be the shift point, it will stay in 3rd. Next time this happens, try giving it some help with the pedal to, say, 5 mph over set speed and let off the pedal. If it upshifts, then that's probably what's happening.
I run close to stock tire size and live in an area where there's plenty of hills. In my experience with the CC, I've noticed the reluctance, it seems sometimes, to get back into 4th after a climb. But, it has always eventually returned to OD. I have to say, that in maintaining a certain speed, my 80's CC does very well, compared to other brand rigs that I've driven. The only negative thing that I've experienced with the 80's CC is when I slow down to below the minimum set speed, after having previously set the CC, when I return to speed above the minimum and hit resume, it has lost the setting. I turn it off and back on, set speed and it's back to normal. The Ford CCs that I used to drive would remember the last set speed until you either shut off the CC or the vehicle.
