Build Crazy Old Man on a Mountain 1987 "MOXIE" FJ60 Build!!! ***Trail Tailor Time***
The rust looks similar to my situation. Curious about the body mounts under the rear seat and how Kelly fixes them. This is such an awesome build by some of MUD's finest.
What lockers are Jason installing?
its all Latin to me... only @TRAIL TAILOR can answer that question :rofl::rofl::rofl:
hey @MoaByte how much wieght will the LS3 Erod pull? lookin at towable Campers.
It will pull way more than a 60 can. It's about the brakes and the way our transfer cases are engineered. The get hammered by the push-pulling. You know that the FJ60 didn't come with a factory hitch? Lol, well there is a reason. With TT's bumper you will be able to tow but you want to keep it light. I'm sure others with v8 swapped will chime in. But the 60's long rear end makes skill backing a trailer.
whats that mean? lolololol
I'm sure you've been in a situation where only one rear tire is spinning and possibly one front tire spinning and you felt lied to. Lol, I did.
Anyway, there are remedies to get both tires (or all 4) to spin together when you need them to. All have their pros and cons and all require a learning curve. Some of the 80 series came with selectable lockers from the factory (but the bastards got stuck with an automatic transmission:flipoff2:). I don't have lockers so I have to rely on my ability to pick a line and sometimes, I gotta turn back. Which really sucks when the bastards in the 80 series get to keep on going (even though they can't drive a stick:flipoff2:). Anyway, this something you shouldn't overlook.
Chuggin along.... @kelly saad 🤩🤩
DESCRIPTION OEM PART NUMBER QTY NEEDED PRICE (EACH) VENDOR NOTES NOTES
FRONT DOORS
Door Seal Weather-Stripping (RH) 67861-90A00
(LH) 67862-90A00 1 of each $80.00 TPD Maybe Discontinued, but TPD had them
Glass Run Upper 68141-90A03 2 $67.00 TPD
Glass Run Lower 68143-90A01 2 $20.00 TPD
Front Door Cushion 90541-09006 4 $2.01 TPD
Window Felt Outer (LH) 68210-90A02 1 $28.00 TPD
Window Felt Outer (RH) 68160-90A02 1 $28.00 TPD
Window Felt Inner 68170-90A01 2 $39.00 TPD
Window Crank Plastic Washers 69266-22010-08 4 $1.13 TPD
Door Rod Silencer Foam 69759-30021 4 $3.50 TPD
REAR DOORS
Door Seal Weather-Stripping (LH) 67872-90A00 1 $40.00 City Racer Discontinued: Price shown is for a City Racer Aftermarket Part
Door Seal Weather-Stripping (RH) 67871-90A00 1 $40.00 City Racer Discontinued: Price shown is for a City Racer Aftermarket Part
Glass Run 68142-90A01 2 $93.13 TPD City Racer has aftermarket for: $45
Window Felt Outer (LH) 68230-90A01 1 $20.00 TPD
Window Felt Outer (RH) 68180-90A01 1 $20.00 TPD
Window Felt Inner 68190-90A01 2 $39.00 TPD Discontinued:
(Use front felt and trim down)
Small Side Window Gaskets (RH) 68188-90A00
(LH) 68189-90A00 1 of each $96.00
(for both) City Racer Discontinued: Price shown is for a City Racer Aftermarket Part
BODY
Windshield Gasket 56121-90A05 1 $118.00 TPD
Rear Window Gasket 68291-90A00 1 - SOR Discontinued, but SOR still has OEM - otheres may have OEM as well (12/2020) City racer has aftermarket for: $95 (non-chrome)
Cargo Window Gaskets 62741-90A00 2 - SOR Discontinued, but SOR still has OEM - otheres may have OEM as well (12/2020) City racer has aftermarket for: $136 (non-chrome)
Rear Liftgate Upper Gasket 68282-90A00 1 $65.00 City Racer Discontinued: Price shown is for a City Racer Aftermarket Part
Rear Liftgate Lower Gasket 68281-90A00 1 $85.00 City Racer Discontinued: Price shown is for a City Racer Aftermarket Part
Fuel Door Lock Pad 69513-14010 1 $6.00 TPD
Fuel Door Cushion 90541-08003 2 $1.85 TPD
Gas Filler Neck Grommet 90480-92002 1 $19.00 TPD
Gas Filler Neck Gasket 77293-60030 1 $6.95 TPD
Rear Hatch Lock Bezel 69563-90A00 1 $45.00 City Racer Discontinued, but still available from some vendors
Rear Tailgate Lock Grommet 90480-10102-01 1 $1.39 TPD
Trail Tailor Door Seals (full Kit) Aftermarket 1 $280.00
(Full Kit) Trail Tailor
Windshield Wiper Pivot Cap 85247-90A01 2 $13.00 TPD
Front Turn Signal Lens (LH) 81521-90A00 1 $36.38 TPD Quality Japan Aftermarket from FJ Parts: $24.50
Front Turn Signal Lens (RH) 81511-90A00 1 $37.37 TPD Quality Japan Aftermarket from FJ Parts: $24.50
Front Turn Signal Lens Gasket (LH/RH) 81512-90A00 2 $6.80 TPD
Front Side Marker (LH) 81740-19285 1 $21.25 TPD
Front Side Marker (RH) 81730-14110 1 $21.25 TPD
Rear Side Marker (LH & RH) 81750-91255 2 $21.25 TPD
Tail Light Gasket (LH) 81562-90A00
(RH) 81552-90A00 1 of each $56.00
Tail Light Lens (LH) 81561-90A00 1 $60.00 CruiserParts.net
Tail Light Lens (RH) 81551-90A00 1 $60.00 CruiserParts.net
Headlight Door (RH) 53131-90A01 1 $145.00 TPD
Headlight Door (LH) 53132-90A01 1 $145.00 TPD
License Plate Light Cover 81270-95A09 1 $155.00 FJ Depot Discontinued, but available by some vendors
Land Cruiser Side Badge 75370-60020 1 $55.00 City Racer
Rear Hatch Struts 68950-69025 2 $35.00 TPD
Horn Ring Contact 45176-20030 1 $11.00 TPD
Horn Contact Pin 84312-20011 1 $5.75 TPD
CLIPS
Tail Light/Front Turn Signal Light Retainer Clip 90189-05013 16 $1.19 TPD Works for both the tail light and the front turn signal lens
Tail Light/Front Turn Signal Light Screws 90154-50001 16 $1.24 TPD Works for both the tail light and the front turn signal lens
Side Marker Retainer Clip 90189-04014 16 $1.11 TPD front side markers, rear side markers, front vents, front grill center
Front Side Marker Screws 93219-64016 4 $1.44 TPD Discontinued?
Rear Side Marker Screws 81739-22060 4 Discontinued
Sill Retainer Clips 90189-05012 20 $0.88 TPD
Sill Trim Screws 93566-54516 12 $0.84 TPD
Headlight Bezel Retainer Clip 90189-04069 8 $0.76 TPD
Headlight Bezel Screw Upper 90167-40010 2 $1.01 TPD
Headlight Bezel Screw 90160-40002 6 $1.02 TPD
Front Vent Retainer Clip 90189-04014 counted above
Front Vent Retainer Screw 90162-40006 4
Rear Vent Retainer Clip 62909-22010 8 $1.36 TPD
Rear Vent Screw 90159-35001 8 $1.12 Discontinued but available from toyotapartsdirect.ca
Rear Chrome Tread Trim Screw 93546-24516 6 $2.50 Discontinued but available from Cruiserparts.net
Front Grill Clips 90467-12008 8 $1.55 TPD
Hood Prop Clip 53452-90351 1 $4.07 TPD
Hood Prop Grommet 90480-15002 1 $3.00 TPD
ENGINE BAY
Hood Bumpers 53382-90A00 2 $8.00 TPD
Hood Insulator 53341-90A00 1 $217.00 Toyota Dealer
Hood Insulator Clip 90467-09014 20 $1.05 TPD
Front Hood Weather Strip 53381-90A00 1 $45.00 City Racer Discontinued: Price shown is for a City Racer Aftermarket Part
Rear Hood Weather Strip 53383-90A00 1 $55.00 City Racer Discontinued: Price shown is for a City
CLIPS
ENGINE BAY
left to find....
FRONT DOORS
REAR DOORS
BODY
CLIPS
ENGINE BAY
Wow! Thanks for posting this, my outer window felt is not fitting correctly, I can’t get it to stay “clipped” in. I think I got the wrong felts. This part number list will help 👍
FRONT DOORS
REAR DOORS
BODY
CLIPS
What's that total? Feeling noxious... But such is married life.. $126000 for a Lexus 600
idk...im scared tho :rofl::rofl::rofl::rofl::rofl::rofl:
List was sent to me from @kelly saad Its a painful list :rofl::rofl::rofl::rofl::rofl:
Best you might to is to source them yourself to save a buck. It's just time. The important part is the quality. OEM has a 35 year service life. That's not only why everything needs replaced, but why it's worth the money to go OEM. The exceptions are guys like Kelly and Jason who go beyond and make these trucks even better. If I had a better budget, I'd do what you are. I have the blessings of being able to do Many things in my driveway Incase I have to do it again.
have spent a cpl hours puttin it togther as much OEM as possible. Lotta things NLA tho...and believe it or not...OEM is more likely to be cheaper on a Toyota site than Ebay ect...
