Crazy death wobble?
so i tightened pretty much everything today, got a half turn or more on bottom knuckle studs on one side, as well as a few turns on steer shock bolts. Also tightened sway link ends and steer arm nut!! Found out i set up my alignment with too much toe in so i adjusted that. Death wobble gone! I do still get a shakey wheel when going over manholes and such but it doesnt build up and is fairly minor considering. I think i may pull the wheels off and re-torque wheel spacer bolts, as well as maybe move the steer shock this week. some pics of high steer and steer shock to make the thread complete:
View attachment 258066View attachment 258067View attachment 258068
Hi @cody c , I know it's been a long time since you have fixed this issue, but I was wondering if the death wobble ever came back, and if you found the exact culprit? I have recently picked up an 85 FJ60 (which I love), but I can't drive too far without having to pull off the road due to the wobble. The list of fixes you put together is good information that I'll follow, but I was wondering if there was anything else I should look for. Thanks for the information.
The vehicle had been gone a long time, but the TRE’s seemed to have been the weak point. I think with 40” tires that aftermarket one ton components to be a smart upgrade. When things are out of balance it’s constant vibration forces that loosen things up and are your enemy. Having the steering firmly connected to all components let’s the mass of everything soak up the vibrations better (heavier mass lower frequency)
I have seen tire pressure cause it, on big rubber. A simple change of pressure fixed the issue.
On Cody's original truck, drag link angle must have caused so bump steer as well. Your drag link needs to be as level as possible to not have bump steer.
Set studs with red locktight.
Cheers
@cody c @pithicus @SNLC @Michael Hanson , Hello all, Thank you all kindly for the responses. I think all this information gives me several good starting points, but I will start with the tires out of the gate. I may reach out to some of you as I work through this process. Thanks again!!!
Hey feel free, generally not that hard to nail down what is causing death wobble or bump steer.
What size tires are you running?
Cheers
Running some old 30x9s right now, but I'm planning on putting some 32s on. I'll probably have to get a lift before I can do that though.
As a general list .. Check spring bushings, wheel bearings, unbolt torque, Steering gear adjustment, tire condition, wheel balance, tie rods and end links, alignment.
