Cracked intake manifold ?
Well, a vacuum leak. Does it backfire through the carb? Won't idle?
Are you running a header or stock intake/exhaust?
Ed
F or 2F?
If the crack is directly under the carb in the manifold and your running a stock exhaust manifold... a stuck heat riser is the culprit....
I had the same problem with a crack in my intake manifold due to the heat riser being stuck. This is a classic issue with 2F engines and can also lead to issues with the flatness of the assembly besides a cracked intake manifold. I had my manifold TIG welded like the previous poster and it works fine. When I removed the intake and exhaust assembly it sprung from the internal stresses and a flat edge showed an 1/8" gap in the middle.
