IdahoDoug said:As for "repacking" the rear axle", you might post a question here as to how it's done because that wording sounds like you're expecting to find similar stuff in the rear axle. You won't.
DougM
NorCalSam said:[Moreso, we have owned other 4x4 vehicles with double the mileage and never have done maintenance on these parts and never had problems. We're probable just lucky, or maybe they would have never broke considering they didn't weigh close to what the 80 weighs, and they weren't locked. I think all of the factors lead to the problem (grease, weight, wheeling, lockers, etc...) Not just grease.
Teresa
LOL
NorCalSam said:Anyway the job is done I asked the tech to check everything and he said that all the seals looked good Knuckles, spinndles etc. So the job is done for now.
landtank said:This is one of those things that is so often talked about we don't always cover the basics everytime.
My best advice to you is to ALWAYS get your parts from CruiserDan, he's got your back!
to 1/2
Beowulf said:Sam,
This is my last post in this thread 'cause I'm starting to sound like a nay sayer.
You should verify that the tech replaced the inner axle seal. This is a $2 part and critical to a successful birfield repack. From what you have said, your inner axle seals have never been replaced up to now. If that's true then there is absolutely no way that the inner axle seals were OK. Two reasons.... Diff fluid was in your knuckle, and your truck has >160k miles. Those little seals should be replaced at ~60k miles; especially on the long side. For the Tech to inspect that seal he would likely have to destroy it. I don't think you can get it out without messing it up but regardless, it is unthinkable to put in new birfs and not to replace that seal and all the other seals.
Bottom line: IMHO, If the inner axle seal was not replaced with a new Toyota part then you have a problem on your hands.
I'm done.
-B-
Just to be clear, did Bobby Long say that for on road use OEM would last longer?robjam said:...I considered the Chromoly longfields. After speaking with Bobby and him realizing mine is a DD, he thought OEM may be the way to go...
Rich said:Just to be clear, did Bobby Long say that for on road use OEM would last longer?
