Crack in the frame!
Dallas
Website
www.octagonmma.com
Both sides have this same fissure, which is located behind/below your butt were you sitting in the FJ. Not your asscrack either. What kind of a problem does this pose? Pic is the passenger side crack. Weld them up?
I also noticed what seems like a bent lower front shock mount, but can't tell. Opinions welcome.
I can take better pics if necessary as I took these with the RAZR.
Can't say I've ever seen a cruiser frame crack. In that pict, is the body off the frame?
I think I'd weld it. If you have a tiny right angle drill and could get to it, I'd stop drill it first too. If it is hard to get in there and weld it, then go on the side of the frame where the two halves of the rail are together and lay a few of one inch beads top and bottom. The shock mount doesn't look like an issue. Even if it was screwed up and it did fail, it wouldn't be that bad. I'd put a nut on it and hammer and pry it where you want it if it is bent, then gusset the back side of it.
This statement is sure to generate a lot of pictures....it is very common on vehicles in the rust belt, and on ones that get used, hard. :)
Is that area just aft of the hanger for the rear leaf spring in the area where the frame starts to get boxed again, or in front of that hanger?
Shock mount should match other side mount. If not then bend it back and reweld. What kind of lift do you have and are your bump stops correct.
The frame is a hard one It first needs to be cleaned out and to really see how far it goes. More than a couple inches long and my advise is out the window. Id clean very well. Grind out the crack in the shape of a V and re weld with a good welder. I would also add a scabb plates over the outside of the frame at least 6 inches, do not make it square as this will transfer all the stress to the point right after the scab plate but in a triangle or v pattern as to distribute stress. You ought to be good to weld just a section of the two frame halfs together but only in a small section. The rivets are designed to alow for flex of the frame. By only welding a small portion of the frame together you should be okay.
If your frame has been this way for a while you have probably flexed and bent other stuff weekening it. Since this week area sit's under your ass and passengers ass (where the tank may reside on early cruisers) in a wreck this will be probably be your week point. Not a situation I would like to be in.
Personall it looks like the vehicle has been in a wreck or wheeled really hard. If the crack was in the front or back of the frame I'd weld and not think anything of it. In the center and I would be looking for a new frame. They are pretty easy to come buy. The replacing is the hard part.
I thought it was only heeps that did that.:eek:
Have you ever seen a cruiser in real life? I mean one that hasn't just been driven down dirt roads and such. It happens on a pretty regular basis.
I guess I'm the only rock cralwing California cruiser that hasn't had this problem then it seems.:doh: Dirt roads aren't my cup of tea. More like Rubicon, Barret Lake, Bassy Falls(when it was open), Fordyce.:flipoff2: Then again, I'm not on me knees checking my frame in the garage, I'm wheeling it;) , when it runs:frown:
Personnaly, all the cruiser I've come across, both of mine now, and my friends, I haven't seen this problem. That's all:beer:
campy said:
I guess I'm the only rock cralwing California cruiser that hasn't had this problem then it seems....like Rubicon, Barret Lake, Bassy Falls(when it was open), Fordyce. Then again, I'm not on me knees checking my frame in the garage, I'm wheeling it....
If you are not on your knees and your back inspecting your truck before and after it is run on some of those trails, then I would suggest doing so. Not doing so, is not an advised practice, that’s for sure....
It continues to amaze me the things that you find when a truck is clean and you spend some real time under it, looking at things.
:beer:
:beer:
:idea: will do.
For all we know they are all cracked right there. If I have the perspective on that picture figured out, you'd have to use a mirror, or pull off the body to see that spot.
Here's some from the bottom:
