For Sale Couple Classic BMW's e30 and e28
Status
Not open for further replies.
Zionsville, IN
1991 e30 325i 5 speed manual, black over tan. Very clean interior, little surface rust. OD/cluster stopped at 169K. Does leak some oil $2500
No it's clean clean
Opps I lied, you can see on the passenger front quarter up by the head light that is a bubble, but has not come through the paint yet.
There may be a tad similar not through the paint by the antenna too.
533i
Recent Maintenance
This summer
· 2 new dog bones (rear suspension)
Jan 2013
· BMW changed, spark plugs changed oil and filter and adjusted valves at 217,000 miles
Changed out the heater blower motor for a good used unit
208,082 3/31/2013
· Change Diff/Rear end oil, Castrol 80/90 weight Hypoly
· Change Gearbox oil, Mobil 1 synthetic 75/90
June 29-July 2, 2012
210,400
· Change oil and filter. Castrol 10-40
· recharge A/C leaking at pressure switch on receiver drier
210,500 6/29/2012
· New Water Pump, new heater hoses (all), new upper and lower radiator hoses,
· New coolant, autozone regular (green) antifreeze
· New receiver drier and cut-off switch
· Recharge a/c with 3- 12 oz cans on 7/2/2012
(March 2011)
· New Battery
· New Ground Cable
· New alternator
The silver one has sold, the black on is still available.
Here is more info on the build.
Air ride Air lift company universal air struts. everything on the air ride is brand new.
8 smc 3/8 valves 5 gallon aluminum tank, pressure switch. all new air line and wiring.
Compressor and wiring mounted in spare tire well. Trunk dynamated along with
the back seat and floor area. Trunk has Hard wood flooring and was raised up
3/4 inch to allow for the wiring and air lines to be mounted. It all comes out
with ease to service the compressors or wiring.
10 switch ride control with 2 dual needle gauges.
Has extra air line for gauges about 60 ft,
Has FBSS individual control over all four corners pancake and seesaw. It gets up and down very quick rides
great, No shimmies shakes
Status
