cooling system
Nashville, TN
Im getting ready to change belts and replace leaky water pump gasket, is it right that it take 5 gallons of coolant? Also any tips from someone who has done this to save time and or bloody hands?
With the expansion tank included, I believe it is approx. 3 to 4 gallons. I have 2 gallons of antifreeze and 4 gallons of distilled water for my flush and fill this weekend. I plan to get as close to a 50/50 mixture when done.
Riley
If you're pulling the pump you might as well replace it along with all hoses. This job is SUCH a PITA on the 3FE. The whole front of the motor needs to come apart, all pulleys, air pump, and a hundred other steps I forgot. I did a complete write up on the 3FE Yahoo list when I did mine.
thanks, i hope he has something a little more detailed
My post gives you a list of things to remove and the order in which they should be removed to access the pump. Yes, pictures would have been nice, but I didn't take any. You have all the information you need. It is not rocket science, but you will wind up with a bucket full of bolts.
Read the FSM. All the info on torque specs are in there (which I proptly ignored). A set of stubby metric gear wrenches makes the job easier.
Smear some grease on the water pump gasket to hold it in place on the block while you thread the studs back in.
thanks for the helps guys, got the belts changed and i dont have a leak from the water pump so all is good on that front. I thought i would add some insight i learned in this process. It took about 1.5 hours from starrt to finish. The biggest problem was i didnt loosen the bolts through the idler pulleys, and alternator adjustment bolt enough, they did not want to budge. also the adjustment bolt for the alternator had to be completely unthreaded for it to swing enough for the new belt to go on. On the bright side the only tools you need are 12mm and 14mm wrenches and sockets and a couple extensions. I didn't have to move the fan or shroud, or the battery. removing the passenger side wheel is a must and the skid plate. Thanks for the help and good luck to others in the future.
hey i thought id revive an old post to ask some questions,
how in the heck do i get the cast bracket off with the idler pulley on it that is in the way of the water pump?
what all do i have to remove?
it seems this is the last step and i cant see whats going on or find the fsm and my forearms are torn up from the fan shroud, i am really starting to question any money spent on my 3fe and not on a conversion for sbc. is anyone else feeling the 3fe is the most problematic of toyota motors?
i like the 3fe, own a ford or 2 and then talk about problematic, i can take a look in the am so see how to get the idler pulley bracket off, i dont have the info in front of me tonight
Scroll up on this thread to my post on the 3FE Yahoo group. I gave a step by step on what to remove. Yes, it is a PITA.
i swapped out the old one for a newer one, it was a royal PITA, the bracket that holds the pump on had the lower bolt stripped, i had to wedge the handle from a fibreglass in there and bend the bracket out and the push it down to get the pump off. after replacing the pump and bolting it up i started it up and have a coolant leak on the right side of the new pump at the gasket. I will probally bring it to a toyota guy i trust in town and get him to redo it, i didnt use gasket sealer or silicon and that may have prevented this.
In the last 10,000 kms this 3fe has seen new alternator, battery , steering pump has seen work, had the valve cover seal replaced and valves adjusted, the leaky injectors were fixed and now leak again, and now the water pump, in hindsight i feel i should have ordered the swap kit for the sbc right from the start instead of investing $ into this gutless thirsty over complicated motor.
dont get me wrong though, my other cruiser has the 3B diesel and is simple and reliable and easy to work on comparitively, even with 400,000kms, i would much rather have one in the 80.
