3fe water pump
Nashville, TN
It looks like one of my coolant leaks is from the gasket on the water pump, how hard is it to replace? i will be swapping out the ribbed belts while im at it so it looks like that would help the process. also have you seen much failure in this area?
thanks
i had to replace the water pump and radiator on my '91 @ around 190k (this was about 3 years ago so memory of job is a bit fuzzy). it wasn't too difficult but it did take at least 4 or 5 good hours. if you know how to use a wrench you'll be ok. also i think that job was one that the haynes manual was actually helpful for....
thanks i do have the haynes and a fsm soon to come, looks like the hardest part as always will be the reaching over the radiator to reach the parts lower down
If FJ80 radiator and fan shroud configuration is anything like a FJ62, you are in for some fun times.
looks like a very simple job on the 3fe from looking in my engine bay right now... but everything on this engine looks easy to work with.
:lol:
It's not.
It's not "hard", but it's a very long process. Lots of stuff needs to come off, and each one presents possibilities for difficulties such as seized/snapped bolts, etc.
Sseaman:
1) Go OEM.
2) At the very least, replace the large diameter hose connecting to the pump on the passenger side. You really should replace all hoses to the pump while you're in there, but the others can be reached later if need be.
3) Post up a "Real Time Help Needed!!" thread if you get stuck.
Long Live 3FE!
Curtis
91FJ80
thanks for all the input i like the dropping the air pressure idea, i am planning oem for the new belts and numerous hoses while i have the coolant drained,
i know these dont have the phh what are the hoses considered going to the rear heat mine look some what dried out so i figure ill change them also
thanks
So...in a scale from 1 to 10, how hard or tedious? I have quite mechanical experience.:hhmm:
It would have been much easier had the bolts not been 19 years old. I snapped two thermostat housing bolts and one that goes into the block from the water pump.
Use a propane torch and heat the bolts up before you go at it. Change thermostat while you're in there. Oh yeah try not to snap off the 'brittle' 19 year old wiring on the engine. Those leads are really expensive.
Its a good experience to get to know the front of your 3fe real well!
My 91' water pump had problems last year about this time (bearing seal leaking, a lot). Get an OEM for certain. Why not get one that lasts another ton of years. Mine was a complete breeze except for removing the fan off the water pump before removing the water pump. Those little bolts are hard on my sausage fingers. While you are at it, check to see if you need any hoses replaced. Its the perfect time to do so.
When it came to actually removing the pump, I have to pull with force to get it off the stud (cant remember if there are one or two). If the hoses are original (heater bypass, heater lines, etc) you should consider replacing them then if you have the money. It may seem like you buy a lot of hose, but mine were all factory originals and I needed to replace two of the bypass and heater lines since the water pump (died of old age). So in other words, its worth the initial upfront cost for calmness of mind.
There is a write up somewhere for the 3FE i believe.
