coolant temp sensor spec
Is it plugged into the correct sensor for coolant temp… my 74’ has two sensors near each other … one was for computer? Emissions bla bla
I’ll see if I can get a pic today later … I’m at beach and be around my truck later
Anyone know offhand the range for the coolant temp sensor spec for a 1974 fj40?
I don't. I do see that the temp senders have a number & letter stamped on them. The temp sender that works with my 12/'74 FJ55 temp gauge has 4 K stamped on it...
Can’t read mine … but here are the two sensors I have the one my temp is attached to is the once closer to firewall… the one that’s next to carb is not used … however @Pighead has his attached to the one near the carb
Do you have two on yours? Or just the one?
Mine move around, they're not necessarily in the original locations. I used to have the sender for the smog stuff, it's gone and I've replaced it with a mechanical temp sender. I don't think it matters which one goes where.
