Coolant leak?
My Crusiser has developed a coolant leak. It seems to be behind the intake, towards the middle to back of engine and I cannot visually locate it. Does anyone have information on locations of coolant ports on the engine, before I start taking things apart. I have my fingers crossed that I have not blown a HG.
Heater and rear heater hoses
The PHH is below the starter and is a small section of hose that is prone to leak. To see it you must look up towards it through the driver's side wheel well. Do a search and you will see mant pictures of where it is.
This is what they look like inside after 170k
Abit of a PITA to change but it is a "right of passage" amongst mudders.
If yours has two diff clamps (1 pinch and 1 pin/twist) it is most likely stock.
LX- wrong thread for that picture, or wrong photo??
DougM
Your leak could also be from either of the two bypass hoses at the base of the throttle body.
