Coolant Leak Issue, Near Throttle body.
Sigh, looks like mine was leaking from the crack on the hose...
Trying to find the part. At the mean time, is there a temporary solution to seal that crack?
Does anyone know the part # of this hose? Trying to figure out on the part website, but have difficult to locate the right part #.
It should be this highlighted hose on the manifold, but still couldn't figure out its part #....
Anyone know its name or part #?
Edit: Looks like this hose is for emission control and coolant doesn't pass through it? If so, I have 2 issues then:
  1. The plug on Throttle Body still leaks
  2. Cracked hose for "VSV for EVAP"
Guess I found the part # for the VSV hose: 23829-50070. Just a FYI in case anyone needs it. It's over $30 at local dealer. Guess I will just wrap it with tape to live with it.
Continue tapping the plug now....
That is a vacuum hose and should not be leaking coolant as it should have air traveling in it. Based on the picture I would guess the water is coming from the plug below it.
The little plug on the throttle body on my 2004 LX 470 popped out and spewed coolant. I tapped the plug in flush as best I could on the side of the road and added coolant, but it is still seeping. Also, when I put it in, I put it in with the hole down (pretty sure that is wrong)... I haven't tried JB weld yet, I was really hoping the plug would pressure fit in and seal up...
Can you buy replacement plugs? Any suggestions on getting the old one out (drill it). I would really like to fix this right, but without buying a whole new throttle body...
Any suggestions.
Thanks
Lee
2004 LX470
2000 LC
Has anyone who has preformed the "quarter - JB weld" method to fix this had any other problem with it? My throttle body is seeping now too. I have no apprehension of doing this fix, I just want to make sure it has had good results so I can actually get by with a fix under a few bucks.
Wow!! A possible repair on the Cruiser for under $5. Somebody pinch me o_O
still no issues for me and no leaks
Joined the blown throttlebody plug club this morning. In central Texas and we hard our few days of hard freeze last week.
Did find a more info about it on a tundra forum that shed some more light on the purpose of the plug (manufacturing purpose possibly). Would love to tap it and put a threaded plug in there but the JB-weld/quarter solution will be what I do tonight. Got lucky and the plug landed on the top of the block and rode there for about 5 miles.
On a separate note, can anyone confirm what the hose I have circled below is? It is all cracked up and from looking at diagrams I can't clearly tell what system it is/what is is for. Goes from the drivers side head to the throttle body.
Thanks @flintknapper, you wouldn't happen to know the PN for that hose off the top of your head would you? Mine is cracked to hell, originally thought that was my leak until i saw the well polished hole full of coolant.
I completed the quarter fix a few years ago, and yesterday, I noticed that the quarter popped off. There was fresh pink residue, and the plug was just above flush. I cleaned it up and tapped it down flush. I took a small amount of sandpaper and roughed it up a little, along with the bottom of a new quarter. We will see how long this one lasts. The truck spends most of the time in a climate-controlled garage, but a few nights at the airport a few weeks ago where the temp dipped down into the 20s. Maybe that is what did it.?
Has anyone else had to redo this?
Thanks
Here’s my share to the community;
2004 LX470 throttle body coolant leak by the bypass cap, tapped and capped (with fipg for added insurance) by my local machine shop. While in there all brand new oem bypass coolant hoses.
