Quick question: While flushing, are there any safe descalers/cleaners that anyone has used to polish the cooling system internally?
Thanks. I have already done this and used 3/8” id vinyl tube. A little loose. Something like 5/16” would have been great, I don’t know if I have ever seen that size before.So I just did my first flush of 3 tonight and replaced the thermostat, heater tee's (and 6 hoses) and I examined the main connections to the radiator since they had some staining and crusty-ness.
@Nightbrew, probably too late, but I use some brake bleeder tubing I had laying around to attached to the small block drains on the passenger and driver sides not sure on the exact size but I can check tomorrow. I was able to find both with this youtube video that points out they can be found by following the catalytic converters to the engine. Locating Coolant Drain Plugs on 2UZFE. Maybe it will be helpful to someone.
I had two questions I was hoping to get help with.
- When I opened up the thermostat housing there was some large amounts of gunk on the inlet water flange and the thermostat and gasket were stuck in place with white gunk around them. I pried it out and cleaned it up the best I could. I am curious if I should do anything else. I left the thermostat out while I run through the flushes before the final fill and it is leaking but I assume for now this is because the t-stat and gasket are not installed. Fingers crossed this stops when they are installed. Just curious if I should do anything else with this like replacing the Water Inlet Housing?
- The Front Bypass Water Housing hose nipple (upper radiator connection to engine block) was very dirty. I cleared it off the best I could and it looks pretty severely pitted. I reinstalled the old hose since I didn't have the new one on hand yet. When I filled the radiator with distilled water it was leaking out pretty bad. I am planning to replace the hose tomorrow but I wanted to see how screwed I am with this. Anyway to correct this without R+R'ing the Front Water Bypass? See the pictures below for before/after cleaning.
I had the same concern, but it really doesn't make a big difference.About to do a coolant flush on my 07 lx... confused about using the toyota pre diluted coolant. My understanding is that after flushing the system there is about a half gallon of highly diluted coolant left. Then after adding 3.5 gallons of 50/50 mix to fill the system the mixture is going to be less than 50% coolant due to the highly diluted half gallon of coolant that couldn't be drained. Is this not a concern? Using concentrate this wouldn't be a problem because you could just add a little more coolant than water to the mix going in and problem solved but this can't be done with the pre diluted stuff???
