Cooland Questions
The LX was not happy this morning. It was around -20 out here when I started it up and headed out. A few miles out of town I noticed the temp needle climbing so I pulled over and let it sit for ten minutes. Started it up and the needle was in the middle as usual, but made it's way to the red after driving a bit further.
The reserve was about half full when I first stopped and the radiator was just starting to make a gurgle sound. It was full when I checked it the second time and I had a little bit of coolant on the frame above the exhaust. It doesn't look like it came from the reserve and I couldn't find where it was coming from, but I could hear a drop hit somewhere on the exhaust every ten seconds or so.
After sitting for another 15 minutes I started it up and drove back into town without it overheating. I'm thinking the thermostat froze or stuck. It's running fine now, but the reserve is empty.
It's got 50/50 Toyota red that is less than a year old. I'm wondering where that coolant on the frame came from and if I should increase the mix to 70/30 or so. I put a new cap on the radiator when I changed the fluid, but the T-stat may be the original.
Thanks,
Chad
If there are no leaks, I would say the coolant on the frame is from it puking out of the cap or bottle.
BTW, #284 is my favorite also.
That's just one of my favorites.:)
I think it was coming out of the reservoir's overflow. It was all over the passenger side wheel too when I got under it in the garage. I think my 50/50 mix may have been closer to 60/40. The fluid was a bit dirty when I drained it.
Just out of curiosity, what does your coolant mixture have to do with this problem? Maybe your adding that info in there.....just wondering.
I'm assuming they were wondering if a 50:50 mixture would be OK at -20F. Not something you ever have to worry about in Opelika. In other words, could their coolant have frozen, thus causing the problem(s) (e.g. freeze plug, etc.).
