GM Cool LS motor mods
General Motors, Chevorlet, Pontiac, Oldsmobile, Saturn
I'm starting a thread about additions available for LS motors I've found. Mostly external parts. Post up something cool if you want. I'll start off with a dual alternator bracket. Biggest alternator I've found for a LS is 400 amps. Dual would give 800 amps in case you need to winch up mount everest.
Overdrive power steering pulley
Dual power steering pump bracket:
my favorite mod for a LS is 20psi of boost from a 78mm turbo
I also found this high flow water pump, but haven't found any reviews yet.
Any mods for engine mounts that are model-specific such as for Land Cruiser or other makes and models?
Wiring harnesses to adapt?
There are several motor mount kits. Advance adapter makes a set and several cruiser shops make kits. Wiring gets tricky due to all the variables. A bare bones LS swap takes shockingly few electrical connections to get on the road. I think like 7 wires maybe? There are many generic Wiring kits too.
Installed cog belt drive kit. Personally I would like to try a cog drive system.
Here is some data of the benefits of having vvt. The vvt adds about 40ftlbs of torque at around 2000rpm-important for towing. Keep in mind vvt can be added to a gen3 motor afaik. Some of the wiring will need to be switched around.
Here is another mod:
It's a duramax fan blade. It's 21" in diameter and said to cool better.
Here is a nice set of trunnion arms made by melling:
Mr1341 by melling
