Hi all, just wondering whether or not to convert my full time 80 to part time? Marks do a kit for about 600 bux. Just wanna know if it's worth it, and what advantages it would have on my truck. Also, are they easy to install? Any help would be great, cheers
While I realize this is meant in jest, it doesn't really make sense even in that regard since Toyota uses part time 4wd in some of its most rugged vehicles today.
i have the part time kit. It doesn't really improve fuel economy significantly. about the only thing it's good for is to solve front shaft vibration/rattling issues from a lift kit. It also saves a little on wear and tear and helps extend the service interval for the birfs. You loose the full time functionality and ABS while in 2WD, so if that's important to you, then I wouldn't do it. You will need a CDL switch to make it work. The CDL switch becomes your 2WD/4WD control.
Not a reason to do it, but a side effect is having 2wd lo, or locked 2wd. Not extremely useful, but on a recent trail, I came to a vehicle in the road with nowhere to turn around, so I backed up a hill a bit, locked the rear, with the front disengaged, hit the gas while in reverse and turned the big pig around like a zero turn mower.
If mine didn't have it, I wouldn't buy it. I'd just have less lift to resolve vibes.
If you drive your rig as a dd it saves more than a little front end maintenance. Not recommended if you need a full time 4x4 just to get around. Not good if you have to drive at freeway speeds for long drives , being your tc is locked. Plus the part-time hubs are not as strong as the solid factory flanges. All things considered i would not go back to a full time rig myself. And as previous mentioned about spinning around easy with the front open, you can't lock just the front for spinning the front end around. Although another mod is needed for that. As far as better mileage you dont have to be a mathmatition to figure out that better mileage is a no brainer. You can just weld the viscous to make it solid too if your handy.
Daughter " daddy, it's snowing, can we make cookies?"
Me - "umm, i don't know how to bake honey. Your momma did all the baking while we were married."
Daughter - "no, silly, I meant let's take the cruiser to the intersection and go round and round".
Me "oh, you mean DOUGHNUTS?"
Daughter - huge smile on her face as she's racing out to the 80.
