Console, Tuffy vs. CCOT
Bozeman, MT
Howdy-
Anyone using the 8" tuffy console with the stereo compartment and cup holders, just wondering about fit and mounting modifications that needed to happen. Especially the clearance between the cup holders and the sifter in R, 2nd, and 4th gears. What kind of mods needed to happen to bolt it in?
Also, has anyone used the CCOT center console, it looks nice for a no mod mounting option, but I dont like how the stereo is always under the armrest. I like how tuffs, can stay open even with the armrest down. Anyone use this kind in their cruiser?
Anyone got experience with either of these units?
Thanks in advance!
Rezarf <><
I have the Tuffy
I have the Tuffy with cup holders and like it. The shifter does come very close to hitting and may smash a finger but it only takes a few times and you will learn.
The shifter also blocks the cup holder when in 2nd. I have heard that some people will bend the shifter that is my plan. Mounting was no issue b/c it is mount to an AL Tub 1980FJ40. No exp with the CCOT but it was spendy compared to the Tuffy oh and I do have the stereo model and would never consider a unit that you had to open the whole thing to change the volume.
MJM
I love my tuffy. When on the trail, I keep the main part locked, and the stereo part open incase something should go wrong (roll). when in the city I lock both up.
Get a tuffy- you'll wonder how you ever did without it
I got this at Wal-mart for arround $20, I live in MT and I don't worry about theifs, so in a city it would not be a good idea, but it works good for me. Just a thought if you don't need it for security.
I have the tuffy and like it.
My seats are on a cradle system tied into my cage, and so is the console.
Good luck!
-Steve
I have a CCOT and I am taking it back for the Tuffy. The CCOT is made great, but I can't stand having to open the entire lid to get to the cd player. It's even worse when you are driving down the road and having to lift the lid while driving and trying to work the cd player. Just bought the CCOT so they are letting me exchange it for the Tuffy.
I like my Tuffy
I just used angle iorn in front and bent some flat bar in back. This way I was able to raise it a bit so it would support my arm while driving. I did bend the shifter a little so to clear the cups. Some times hits a Big Gulp when in the drivers side hole.
did the Tuffy in mine, Love it, its not close to the shifter, but if its in 2nd or 4th you cant close the stereo lid
I tossed the pad and replaced it with gray carpet, the pad made my arm sit way too high and was unfomfortable
Its do the same thing again. and I also did one in my fj60(cept the wider one)
g'day
Ive got the 8" wide tuffy without the stero compartment that went into a 84 bj42... i had recaros in there and it was a tight squeeze but it fits without any major mods except for the following:
- Redrilled the holes in the bottom of the tuffy about 10cm towards the front. This pushed the whole unit back enough
- no room up front for cup holders so they go remounted at the back of the tuffy, again, with custom holes.
I found in the stock mounting position id have to grab the shifter knob from the front as there wasnt enough room to shift from behind when going from 2nd to 3rd.. by pushing the console back 10cm's it removed any interference from the tuffy when changing gears.
I have a tuffy on the 79 40 and the shifter hits in on reverse and second gear. I guess I can double check and see if I can move it more back. It's no big deal if it does not. Like mentioned some have bent the shifter some. I like it. over all. liquidoffroad gave me the best deal. I got it last month :)
I have the tuffy with the cd player in it, and all it does is skip on the minor bumps in the road! What cd players are you guys using? I have it securely mounted in the slot with an L bracket and a sleeve. Otherwise i'm rather happy with it.
Travis
Try an Alpine deck. I've blazed some pretty rough stuff with my 40 and the Alpine has yet to skip even once.
I ordered a CCOT console, because it seemed like the best fit - 8" wide. I just installed bucket seats, replaced the stock bench. The opening between the seats is 10". I'm not concerned about the stereo box, probably use it for something else. My stereo is mounted pretty well in the glove box.
I haven't got the console yet, should be here next week. We'll see how it goes. I got it more as an arm rest and for the cup holders than anything else.
Hi All:
Steve, do you have any pics of the seat "cradle?" Can you explain the design - I'm thinking of this idea for the cage I'll be having bult in May.
Sorry to hijack the Tuffy thread!
Thanks!
Alan
Seattle
Alpine, never skips.......
Travis
The best CD Player for anti skip is Eclipse. It would read perfect even when hitting bumps that would hurt you kidneys. I finally wore it out and now have a Pioneer that is not nearly as good.
That is what I was wondering, I can see me now... rolling down the freeway, trying to swap out a CD, lifting up the lid, and ALL my papers and insurance cards flying out at 70 mph! Yeah right... like my cruiser can run 70mph!
Thank you, that is what I needed.
Are you guys running the 8" version? Just wondering.
I am installin some new summit sport seats, and the tuffy... should make daily driving a bit nicer.
Thanks again! Rezarf
