Console Cubby Ideas
Hanford, Ca
Website
instagram.com
So I've been talking to @bhicks about a possible solution to a problem I've been having. I have this kit from 12voltguy.com and can't figure out a good spot to mount the control panel. I was asking him if he had any plans for the center console cubby. He said currently he does not, but he could work on something for me. Only problem is that it would be a 1 off piece and the price for development and stuff would be high. I was wondering if anyone else would be interested in a blank off panel for this area. I'm currently working on a cardboard model to display what I had in mind and will update this post when I'm done with it. Speak up if interested and maybe we can get this done.
Here's something I came up with in about 5 minutes. It's very rough and made of cardboard.
You'll see it's not exactly flush but that's on purpose to allow the fingers under the lid of the console to open it.
Another angle.
I cut a hole to throw the panel on real quick. It's right at the finger tips if you're using the arm rest. There's also enough room behind it for a gauge or something if you wanted to. I've been looking at one of these for my York OBA that's been on the shelf for about 3 years. I think that would be a good place for it with the oba switch right there where one of those coin holders are.
I'm not sure it the plastic that @bhicks uses can be cut or if the holes need to be printed in but a blank thats held in with the bolt on the bottom that could be modified by the buyer would be pretty cool.
@NLXTACY
I have pondered the idea of having a CB radio/HAM radio holder in that cubby. There is a good size bolt on the bottom of it that could hold it. Two arms going up in an angle forming a support bracket at the top. Inverse trapezoid shape.
My drawing skills have a negative value, so I could confuse you more with a drawing, but it's better I don't.
See post 2
You could have two sides going up in a V shape where a radio could be attached. It probably needs to be angled 30 degrees or so just in case the shifter will interfere with it.
What @ElPolloBlanco mocked up I think is the best way to go that would make the most number of people happy. It could be 3D printed but I think just a piece of 3/16" ABS sheet cut to fit and then just add the holes for the switch you have and a 2" gauge would be easy and keep it all to a flat sheet. Then just use a little VHB tape on the sides to bed the ABS sheet where you want it. It's not going anywhere, it's removeable and requires no hardware. If you want you can primer etch and then paint match.
If I had that console I could make one up using the stuff I have here now. But with 3D printing you could customize it to all heck.
Maybe this improvised visual aid is better than my drawing skills.
Right between those two arms you could have the flat area where other switches could be placed.
And then...flat plate up top? That's a whole lot of focus and real estate for a winch switch.
Not sure if you addressed that question to me or the OP.
Up top you don't need anything else. If the sides have holes in there, you could mount a radio (CB/HAM). All the wiring can go straight down into the console, antenna too. On the bottom you could have the plate the OP mentioned, or leave it as is for some more room for storage.
My design requires a flat bottom so the bolt inside the cubby can be used to stabilize the entire contraption. The top would be stable as the radio is attached to it.
So make one and put it on your site and I'll buy it. Well when the site goes up. 2 more weeks right?
Your design is a little overkill for my needs. But it would probably be useful for you if you wanted to stack a CB and HAM in there. Only problem I would see is having to reach over/around it to reach those beautiful cup holders or down to the tcase shifter.
Just send me the opening required for the switch, the hole spacing for attaching it and I'll just cut a piece out and send it to you with the cut out for a gauge. If it works, great, if not then no big deal. It'll just take a few mins so not worth putting it on the site or charging for it :P
Yes, that's true. This car is full of compromises.
ElPolloBlanco, you must work on planes... what kind of switch is that?
I did actually work on planes until about 2 months ago. Look into the plug I put in to pass power through the roof. It's a Cannon (brand name gone generic don't kill me) Plug for the ground cooling fan off and F-18A that we had sitting around after we got rid of all our alphas. I had to order my own pins and backshell though.
12voltguy.com
Standard issue stuff on that site ;)
Very Standard. But it looks nice and it's better built than anything I could come up with. I'm an airframer by trade so wires and stuff must be done via the KISS method. I'll have to get back to you on those measurements. And in response to your earlier message about missing a cup holder area. My thing with @bhicks is that if were to design a cup holder for that area it may be easy to alter the design to just make it a blank off so that people could cut it the way they wanted. Is he on vacation or something? Anyway I'll get those measurements to you for the opening when I can. This police academy thing has me pretty busy.
