Conferr Aux Tank Internal Layout?
Cripple Creek, CO
I have a Conferr auxiliary tank mounted on the rear of my FJ40. I plan to install a modified (to compensate for the tank depth) stock sending unit on the tank. Does anyone know whether the tank is baffled or not; and if so, the location and dimensions of the baffles?
The tank is baffled, but it will not interfer with the fuel gauge sending unit if it is installed on the left side of the tank (I do not know what the right side looks like inside of the tank). The baffle I can see is more towards the center of the tank. I had to weld an extension so the sender would operate properly.
Thanks, I had figured if I locate the hole for the sending unit in about the same place that other (more recent) manufacturers use, I might not run into problems. Your advice confirms that. Thanks again.
