- Joined
- May 31, 2009
- Threads
- 10
- Messages
- 43
OK, so I have an H151 transmission that I want to swap into my 1996 LC. The mechanical aspects of this swap are relatively straight foward since most (if not all) of the parts needed can be sourced from a Toyota vehicle sold somewhere in the world.
My concerns are more with the electronic aspects of the swap. Right now my concern is about what the computer will do without an auto transmission. Some things I know (I think...):
- the speed sensor that feeds the speedometer and cruise control is in the transfer case, which I will retain so no worries there
- if I unplug the speed sensor on my current auto trans I do not immediately get a check engine light and the trans still seems to shift like normal, don't know what to make of that but it seems good since there is no secondary speed sensor on the manual trans
- unless I fool the vehicle into thinking that the vehicle is in park I will not be able to get my key out of the ignition because of the interlock with the auto trans shifter
Now, there are other harnesses that plug into the auto trans that I have yet to unplug to see the effect. The guys at my local dealer say that I will get a check engine light because the computer will think the shift solenoids in the trans are bad. Has anyone had a check engine light because of this?
I could probably build a circuit that will mimic the electrical characteristics of the shift solenoids to fool the computer, however I wonder if the computer will dislike sending the shift command to the trans and then not having the engine RPM change (since I may not shift the manual trans when the computer is telling the non-existant auto trans to shift). Another possibility is a computer from an overseas 1996 LC with a manual trans in a region where OBDII was standard in 1996. That to me seems like a long shot but it might work. Does anybody know for a fact whether any overseas LCs had OBDII in 1996?
OK, I know those are some loaded questions but they have been bugging me the last couple of days and I have to answer them sooner or later.
Thanks,
Jonathan
Thanks,
Jonathan
