At the bottom, you can see my compression test numbers...
For the past two days (its VERY hot in my garage), I have run a series of compression tests on my '78 40 (2F) - this is the first time I've compression tested it and, given how much power it has, I was surprised that the numbers were so low.
But, I was pretty sure the valves were not properly adjusted - this is the first chance I had to get to it. So, I adjusted the valves COLD and performed new 'cold' and 'hot' compression tests.
I then adjusted the valves HOT and performed the 'hot' tests again - this is where I am NOW.
With the valve cover off and the engine running, I see more blow-by around the number 3-intake valve than anywhere else - at least, that's where it appears to be coming from.
I will be removing my carb this week and sending it off to the FJJim-Spa, for a month or two and, while my carb is away, I have a 'virgin' intake manifold (from Georg) that I will be having milled.
Is there anything in the green results that indicates it would behoove me remove the head and have it milled and install a new head gasket, while my carb is away?
Is there anything that indicates a valve job would be a worthwhile endeavor during this period?
I'm looking for guidance/opinions - what should my next steps be?
Thanks!
Cylinder Cold Hot-Dry Hot-Wet Adjust Valves Cold Cold Hot Adjust Valves Hot Hot
1 115 110 123 115 110 110
2 111 105 100 121 110 111
3 104 100 100 100 95 101
4 105 101 115 110 101 110
5 111 108 109 111 101 109
6 105 111 118 121 115 115
Thanks!
