That sounds like a fusible link to me. Check them with a meter or simply replace them if they're 23 years old.Is there a common clip, or connection that powers the dash lights, radio, blower motor, headlights, and sends power to the dash diagnostic plug? And where would that be? Those are not working on my 97 lx
Don't forget all electrical connections have 2 parts, + and -Is there a common clip, or connection that powers the dash lights, radio, blower motor, headlights, and sends power to the dash diagnostic plug? And where would that be? Those are not working on my 97 lx
All of them. I think there are at least 7 or 8 that the EWD shows the locations of. You said yesterday that it was really wet in your kick panel. Did getting that dried out help?Which ground should be checked?
I know of 4 easily checked ones in the engine bay:Which ground should be checked?
Do your brake lamps work?
Did you confirm this? This is important and simple to check.Let me confirm brake lamps
Short (no pun) of further insight from another member, and after doing all the things you've mentioned, your plan seems logical. Are you working/t-shooting with a fsm or...? Just thinking it might expedite your journey a bit if not.- thoughts? my current plan is to recheck continuity around the egr section of the harness and re confirm where I have power etc, my thinking is a worn wire in the harness, I hope between the egr section and the ecu. I know there are two clips just inside after the firewall, where do they go? And I’m going to open and unwrap the harness near the ecu to check for a short? Any other thoughts or guidance? Cheers peter
