Common electrical connection? SOLVED!!!
So, been digging thru the harness working my way trying to find this short, and this is what I found. The power which feeds the ecu and efi come from the fusible link to the alternator and then there is a splice that carries power back to the efi fuse and thereby powers the remainder of the management system. In my case at least this splice appears to have failed. I now have to figure the best way to splice this wire in without loosing to much cable in the harness. Here is a pic of what I found very close to the alternator
I’ve redone this connection properly, applied heat shrink tube and re wrapped the harness in this area, at the moment all the accessories work and car started and ran properly. Im not quite ready to say solved but all of the issues could be traced back to this as this splice would power the ecu, and the accessories that intermittently did not work
If your splice is solid, I would consider it "solved".
Good job!
That doesn't look like a factory splice to me, but I haven't torn that wire apart yet.
Just splaying a cable and shoving the other wire through doesn't sound right.
Besides, if the end was that close to the alternator already, why not make the wire 4" longer and put a ring term at the alternator stud?
Also, you may notice that the wire has been rubbing on something for a long long time judging from the insulation almost being worn through. I'd suspect it wore through the tape wrapping that joint, shorted to something and burned open that "splice".
If you spliced it well, you should be good to go as @landcrshr commented. Good job troubleshooting! Eric over at SouthMainAuto would be proud!
Yep, I was shocked as to why it was in that condition, I believe it was affected by moisture migrating up the cable and the burn marks could have been from heat and arcing with the loose connection. It was very interesting pulling it apart and seeing how the wiring ran to power the efi , ecu, and the other accessories that where intermittently failing. If it fails again my plan is to extend and put a ring on the end like you advised.
it has been a journey for sure
