Combination switch suitability
Mooloolaba
G'day from Oz
I have a 1989 HJ61 RHD.
My combination switch has stopped working - I have seen the write up on the fix but I am unable to attend to that myself.
I have found a combination switch in Europe with the part number 84301060640 which is supposed to fit a FJ62
Does anyone know if that would fit my HJ61 RHD without any modifications?
Many thanks
G'day from Oz
Many thanks
the whole RHD and LHD topic is going to be your biggest hurdle here to overcome ...........
tough nut to crack ?
if a LHD were to direct bolt on would you consider installing one ?
your stalks would be reversed side , thats it ...
G'day from Oz
Many thanks
here is 100% of your 84310-60640 tech spec data application info:
you tell me if it will fit your modle ID code or not ?
Part 84310-60640 (SWITCH ASSY, TURN SIGNAL) was found on the following models:
MarketDate rangeModelFrames/OptionsFound in diagram
General08/1987-02/1992TOYOTA LAND CRUISERBJ60,HJ6*,FJ6284-01: SWITCH & RELAY & COMPUTER
Model Dates:Matching Models:Model Options:Links to diagrams:
08/1987-12/1989BJ60RG-KRCSTD, GEN, RHD, SRF, 3B, DSL, MTM, 4F, SOB84-01
08/1987-12/1989FJ62RG-KNGX, GEN, RHD, SRF, 3F, CBR, MTM, 4F, LUB84-01
08/1987-12/1989FJ62RG-KRCSTD, GEN, RHD, SRF, 3F, CBR, MTM, 4F, SOB84-01
08/1987-12/1989FJ62RG-MNGX, GEN, RHD, SRF, 3F, CBR, MTM, 5F, LUB84-01
08/1987-12/1989HJ60RG-KNGX, GEN, RHD, SRF, 2H, DSL, MTM, 4F, LUB84-01
08/1987-12/1989HJ60RG-KRCSTD, GEN, RHD, SRF, 2H, DSL, MTM, 4F, SOB84-01
G'day from Oz
Many thanks
G'day from Oz
Many thanks
I believe you want part number 84310-60680 . That looks to be for a RHD rig. That may still be available new from Toyota, worth a check.
G'day from Oz
Many thanks
good evening Chase :)
843410-60680 is a 24v unit .....
fyi...
this may be his case or not ?
i unicorn hunter'd globally and did not find any available verified sources ?
but , if you found one , PM him @toppleover and let him know for sure ...
its good to chat with you again
kinldy matt .......
Yup, I saw that it was 24v but not sure what voltage his rig takes. Also, I question wether a 24v switch is actually different than a 12v switch. Electrics should be the same since there is nothing much in the switches that would make me think they are voltage specific.
