For Sale Colorado - 1988 4Runner - SAS, rock crawler
Albuquerque, NM
Posting this for my friend, if interested, PM me and I will send you his contact info.
1988 Toyota 4 Runner SR5
Approx 201,XXX miles
Truck is in very good condition for a rock crawler with an extensive list of mods.
Price $10,500
Exterior / Drivetrain:
  • 22RE Fuel Injected
  • 5 Speed
  • SKYS Off Road Frame Mod
  • Bilstein 5100 Long travel shock
  • Front Custom Shock Hoops
  • GM 1 Ton Leaf Springs
  • GM Corporate 14 Bolt Diff With Superior Axle Upgrade – Limited Slip (Rear)
  • Dana 44 With Superior Axle Upgrade & Exterior Cage (Front)
  • Warn Hubs
  • 5.89 Yukon Gears Front & Rear
  • ARB Air Lockers Front & Rear
  • ARB Compressor Under Hood With Quick Connect Air Fitting
  • 4 Wheel Disc Brake Conversion
  • T-Case E Brake
  • Tom Woods Custom Double Cardone Front Driveshaft
  • GM 1 Ton Rear Drive Shaft
  • Hydraulic RAM Assist Steering
  • Trail Gear Double Transfer Case W/ 2.28 & 4.70 Gear Reduction
  • Viair 400 Compressor &Tank with Quick Connect for airing up or running air tools (100 PSI)
  • Optima Yellow Top Battery
  • Milemarker 10K Winch
  • Goodyear Kevlar 37 Inch tires W/ Spare
  • Black Steelie Wheels
  • Rigid LED Light Bar
  • DOM Tube Stinger, Rock Sliders & Rear Bumper
  • Steel Braided Brake Lines
  • 3/8 Steel Heavy Duty Transfer Case Skid Plate
Interior:
  • Stock 4 Runner Seats With Neoprene Covers (Front & Rear)
  • Full DOM Roll Cage With Grab Handles
  • Sony AM/FM CD W/ AUX Port
  • Heavy Duty Rubber Floor Mats (Front & Rear)
  • Cobra 40 Channel CB with Weather Radio
  • Wilson W1000 Magnetic Mount CB Antenna
  • ARB Light Up Rocker Switch Panel
  • Viair Pressure Gauge and Rocker Switch
  • Dash Mat
  • Ammo Box Center Console With Double Cup Holder
  • Ammo Storage Box In Rear
  • Quick Connect Compressor Fitting W/Air Hose In Cargo Area
  • Truck is rust free, except for what is noted below on quirks & issues.
Extra’s
  • Tube Doors (Driver & Passenger)
  • Spare Front Driveshaft
Newer Parts Added & Maintenance:
All New Within Last 7K
  • Clutch
  • Fuel Pump
  • All Trail Gear Parts
  • Rear Tires
  • Valve Cover and Valve Adjustment
  • Viair Tank & Compressor (new with last year)
  • Rigid Light Bar (2 Years Old)
  • Newer Maaco Paint in Good Condition (Truck Always Stored In Garage)
  • Only Synthetic Lubricants Used
Quirks & Issues:
  • Front tires – Low tread – 20 % tread left / Rear Tires and Spare at 90%.
  • Some Body Damage – Mainly on passenger side lower body
  • Have used truck as a driver short distances (50) miles around town and to and from trail heads up to 100 miles but truck is more set up for off road & rock crawling. I trailer 4 Runner when going out of town or any long distances. It is titled, tagged and is completely legal for on road driving.
  • Has no sway bars for on road driving, so has some body roll.
  • No noticeable oil Leaks but some seepage in areas.
  • Some very slight surface rust on removable top on metal trim pieces
  • Some cracking on front bump stops
You commented on one of the pictures it looks like, not the thread. No worries. Enjoy the new rig! That rig is what got me hooked.
I don’t know why my post did show up. But I am picking this thing up this weekend.
Be sure to post up about your new rig to share with us!
