Coilover shocks in stock location
FOG TOWN->SF<-
Has anyone installed coil overs in the stock location? Obviously you’d have to go eye to eye conversion on the locations with the stem.
It’s just you’d get a better option for spring combinations(dual) and potentially better shocks that has different valving for certain weights.
If you went that route which Brand and valving did you go with? Size of shock (I’d like to fit 12 inchers if possible)? Is this even possible with the amount of space we have in the stock location?
I’ve seen prices of drop ins shocks that are at custom coil over range. That’s why I ask.
Also you are able to link the front in the future if you wanted.
See @jcardona1 ... I believe his setup is like that.
I don't see this working.
- I don't expect you will be able to fit a coilover in the stock shock mounting brackets from a clearance perspective
- The stock shock mounting brackets are designed for shocks, not springs so reinforcement would be required.
- You will be severely limited on coilover length
- Why bother ? If you're going to go to the trouble just weld in new coilover mounting hoops. In the grand scheme of things this isn't a big project.
Also you can link a truck without replacing the coils/springs with coilovers.
