I had a coil pack go bad in #7 last spring, then in #8 a month or so ago. After the #8 went I changed the plugs (NGK's, my favortie). THEN, yesterday, I decided to really clean the engine with a high pressure hose (mistake!!). A couple of days ago and it began throwing several codes, PO301, 302, etc. So, I took all of the coil packs out and dried them out (there was moisture in the tubes to some the plugs). Ran OK for a few miles, then stumbled. Now it's down to one code, PO301, a seemingly old, maybe original, Denso coil pack. I'll take it out again today and see if there's still moisture present, if not a new Denso goes in. Now I wish I hadn't cleaned the engine but I hate having it so greasy- the rack and pinion steering boots had failed and sprayed all over. I've had this truck about 5 years and it's obvious that it was poorly maintained, so I've been "catching up" on it. Nice driver but pricey. I've had my 80 for 14 years and the only thing that's gone bad on it has been the HG! The 100 is more trouble prone, it would seem.
Ned
