Code 71?
Fort Apache: Victoria
It's an EGR fault reading; can anybody be more specific on what, exactly, a 71 code means?
Had the same code. You need to clean out the carbon in the hoses leading to and from the EGR valve. There is another hose that runs into the intake that can also get plugged up with carbon. I just cleaned them out and cleaned the code and that was it, fixed.
Read this thread:
https://forum.ih8mud.com/showthread.php?t=115298&highlight=egr+code
Your temp sensor is not reading the EGR temps it wants to see. It can be for a variety of reasons. Cleaning the sensor itself should be the first place to start. The pics in that thread are of a 94. The temp sensor is located elsewhere on a 95+. Cleaning it was all that was needed to fix my code 71. Easy and free.
I ordered my FSM last week.
Okay, I cleaned the temp sensor and reset the EFI, but the CEL is still on.....
I *think* I cleared it; I unplugged the EFI main fuse and left it our for a few minutes.
Since I'm now in for the night, I unplugged both EFI fuses (the main and the 7.5) and I'll leave them out all night. That should reset any smartypants CPU.
If that doesn't work, maybe I'll just disco the negative battery terminal for a few minutes and see if that resets anything.
You'll probably have to have the code removed, since some computers have a pretty good memory... Perhaps the same shop that scanned for the code(s) will remove it for you the next time you visit. ;)
Oh, and your Longfields were ordered today.
WHEEEEE!! No more CEL! I guess I didn't unplug the fuses long enough yesterday. I tried a second time (overnight), and no CEL all day today!
With that and recently removing my ABS light, no more amber!
My CEL for that code stayed off for a week after I pulled the fuse and then popped right back up. Give it time.
To trigger the code again after being reset the ECU must see 3 engine on/off cycles each of which is 60 mph or more for at least 5 minutes at a time. So....keep your fingers crossed. Let us know if it worked.
Hmm.... IIRC I did do three different ignition sequences today, and I think I was over 60mph each time. I'll make a point of it tomorrow.
I think if the code comes up again, a second cleaning of the temp sensor might do the trick; my cruiser sat for about two months before I bought it, so I bet there's all kinds of crud and sediment in the system. I've only driven it about 300 miles since I got it.
Wow, uh.... GOOD TO KNOW! If this is in the FSM, I haven't read it enough yet.
I cleaned my EGR temp sensor a couple weeks back after consistently recurring code 71, so far so good since the cleaning....
I think it's mostly carbon deposits, I doubt they will re-accumulate that quickly...
D'oh! It's back..........................................................:doh:
