Code 71?
Iron Yuppy,
You don't like ABS, disconected or broken?
Cool part of the CDL switch MOD........in ugly slippery down hill stuff that does not require low range (usually where your ABS has you screaming like a school girl) .........hit the button...... center diffs locked and ABS is OFF.............shut up girls i have real brakes again.
A must for greasy Lake Cowichan logging roads;)
D'oh! It's back..........................................................:doh:
Same code? Or did you jut peel the onion to the next one?
Iron Yuppy,
When we had the front end apart last week, there was evidence the ABS sensors had been rubbing against the ABS ring on the birfs. So I clipped the tips off the sensors. I thought that was preferable to having them snap off and float around in the grease.
AFAIK I still have rear ABS, as I've replaced the fuse. I just got rid of the light and the front ABS.
