I've been trying to adjust the rod length on the slave. My clutch is high, really high, like the first 2-3 inch on the pedal travel is enough to engage the clutch.
So i reduce the rod length, i then get a small 1/8" play between the rod and the fork. But obviously if i go press the clutch the slave will only take this play and the play will be gone. consequently only moving the slave piston toward the fork. Seems to me doesn't mather how short the rod is the piston will compensate the play?
This high clutch has been driving me crazy. Clutch was replaced 6 month ago. A new Master clutch was installed couple weeks ago and slave maybe 2 years ago all with OEM.
Is there a step by step instructions to adjust everything?
