Clutch Question
SLC UTAH
Will a later model pressure plate (79-86) fit in a early model (1974) fly wheel? I am putting a 1990 3FE into a 1974 FJ55 (1F motor) using the clutch and tranny/tcase.
Just need to know if I can go out and buy a later model clutch/pressure plate to put in.
Thanks for the assistance.
Russ
If I understand your question correctly, no.
You need the pressure plate to match the flywheel. Preferably, you should use the flywheel (with matching pressure plate) that goes with whichever bellhousing you are using. This will help avoid issues with the throwout bearing and release arm.
I got a new pressure plate from my local parts store for $60 and they had it the next day.
Thanks for the responses. Can you buy a early 74 multi-finger pressure plate rather then the 3-finger pressure plate....or if I buy the late 74 multi-finger pressure plate will it work correctly in the early 74 bellhousing? Did the flywheel or bellhousing change between early and late 74 models, or did just the pressure plates change from a 3 finger to the multi finger.
Thanks again for all the help.
My understanding is that all F engines got the 3-finger pressure plate and all 2Fs got the diaphragm style. The flywheels are dramatically different and the parts are not interchangeable from one style to another. I'm not aware of anyone that makes a diaphragm pressure plate for the F.
The bellhousing seems to be specific to the motor (and, hence the clutch components) as well.
So, the short answer is that 8/74 is a break point. It sounds like your application dictates that you use the earlier stuff. It may be possible to modify the release lever pivot (you'll have to space it out) and slave cylinder mount to make the 2F-style clutch work in the F bellhousing, but I lost patience with trying and decided to use the F clutch components instead. The 2F clutch setup is considerable narrower and the main problem I had was that the release bearing would slide too far off the tranny's front bearing retainer.
There's really nothing wrong with the 3-prong pressure plate. That thing is HEAVY and I've seen no evidence of uneven disk wear or contact in the ones that I've removed.
or you could buy a 4 speed and use a 2F bellhousing and assembly.
something else was brought up about this on a thread I started. make sure the crank has a hole in it for the pilot bearing.
I was going to ask about this but forgot... Does an F/2F flywheel bolt up to a 3FE crank that was originally intended for a flex plate?
there's a hole in this theory.
i have a 75/40 with an F(as in not a 2f) with a four speed housing/tranny, using the earlier 3finger pressure plate. of course all the clutch parts are matching, fly, pressure, disk and throw out bearing.
That sounds like a 74 to me. What's the problem?
because the motor is from a 71 and the truck is a late 75.
What I have is a May 1974 FJ55 with the 1F and the 4 speed. It looks to be all original. The bellhousing off the 1F bolts perfectly to the 3FE block. I just wanted to switch the clutch out from the 3 finger to the diaphram style. The clutch that is currently in it looks to be ok, I was just not a fan of the jerkiness of the 3-finger style compared to the diaphram style.
I have the complete 3FE with matching tranny and tcase. The tranny and tcase out of the 74 was just completely rebuilt and in great shape. The automatic out of the FJ62 is toast from what the PO said.
Sounds to me like I would be better suited to just use the clutch that came out of it all and resuse it all.
You guys made some great points. I will continue to do some searching and see what other options I have are.
Thanks again, and any more input anyone has, I would be greatly appreciated.
Russ
