clunk going over small step
Fort Langley, BC
I've got a minor issue developing that I can't seem to figure out. When driving forward or reverse over a small (approx 1") step/lip (like the edge of my driveway) I get a small clunk. It might happen more when the wheels are cranked.
I thought tie-rod ends or shock mounts but those seem OK to a one :banana: mechanic like me. I had my neigbour out today helping me try to locate it with one guy driving and the other listening outside. Seems louder inside the cab....
Anyway outside it sort of sounded like the drive shaft clunked right when the front axle flexed a tiny bit going over the 1" lip. The normal driveshaft clunk when going from R to D to R to D isn't that bad.....so I'm not sure if it's really the u-joints or not.
No whinning coming from Drive shaft when on the road.
Anybody ever hear of a u-joint clunk due to a small mall amount of flex? I suppose there's a bit slop in the drive shaft when I twist it.
I've been boning up on Semlin's u-joint write up, guess I'll give that a shot but wouldn't mind some advice from the Pros.
Thanks
R
edit - doesn't seem to be birfs but again not sure of anything.
could a loose wheel bearing cause this? again everything seems fine when on the road.
I'm going to guess it's the infamous front stub axle clunk as it bounces in the inner spindle bushing. I've got a total of around 230,000 miles of driving the 3 80s I've owned and they all did it unless freshly repacked on just the right bump. Just before needing repacks, I noted they all did it more frequently. It's kinda half heard/half felt in the driver's floorboard, right?
Anyhow, that's my guess. If you're applying torque it would be unlikely to be the drive shaft joints as they're under tension and no slack exists to flop around.
DougM
DougM
Good point Doug, I didn't think of that. Torque is being applied so it's unlikely the u-joints. So do I just need to repack more grease into the knuckle/birf (and around the spindle) ? I'm not looking forward to a complete knuckle job....
That's for the tip Phil. I'll check the panhard bolts as well.
Yeah, check bolts - of course the 4 on the bottom of each knuckle now that you mention it, and caliper bolts too.
There's really no way to get more grease into the axle/inner spindle space directly but indirectly you could pump more into the square plug hole. If there's an air gap between the axle and inner spindle it may well work itself in there after a single highway trip making the grease hot enough to flow well.
But it won't go away, will just be less sharp. The cure is eventually to put new spindle bushes in there on the next repack. Or the fancy new roller bearings with an all new spindle would do it permanently.
DougM
Yea I checked the knuckle nuts and calipers as well. I might just repack fresh grease around the spindle by pulling the birf. That's not too long a job. Just need a rainy Sunday.
Also have a look at the swaybar cushion. I just replaced both which resolved a clunk under the same conditions.
I looked at an 80 this weekend that had a clunk coming up and down driveway curbs at an angle. It was sounded like something was really loose -but everything underneath was solid (spare, exhaust, shocks, etc). I could re-create by pushing/pulling on the top of the rear tires (with tire on ground). I didn't have a jack with me, but I would swear it was loose rear wheel bearings (ff axle). You might jack each wheel up and make sure everything is tight.
aaron
IdahoDoug- please check your PMs / fliptag email. Been trying to contact you!
(Sorry for the thread hijack...)
Whups, off to check my PMs..
DougM
I had a similar problem. I thought it was a bushing worn out in one of the rear arms. Turns out the bolt was worn on the inside so that the o.d. of the bolt was loose within the steel sleaved bushing. Bought a new bolt from the dealer and it fixed it. It helped to be under the truck feeling areas for the 'klunk' while someone would rock the truck. It drove me crazy trying to find it as the bolts were torqued to spec, and it sound only happened on small bumps.
Good luck.
Thanks Eric, it is driving me nuts as I'm pretty picky about stuff like this. I figure it would be good to be under the truck to figure it out but I need someone I trust driving.....
On your rear arm clunk: would it clunk when the front was "on the bump"?
Good luck.
Some of this is intensional on Toyota's part I think. The bolts for the front of the arms have no shoulder and actually measure quite a bit less than their 16mm size. I beleive this is to help insure that they don't get seized in the holes.
Riley, the 'klunk' was in the driver rear when the front hit the bump. I presume this was due to articulation/geometry of the suspension. I was surprised to find that the I.D. of the bolt had worn down over time. See part # 129 on the 80 series rear suspension diagram at Specter:
http://www.sor.com/sor/cat102c.tam?xax=28709
I have a slight clunk, I think it's the steering stabilizer. I can clunk it up and down on it's ball pivot mounts.
Riley, did you ever resolve this.
I have a similar rear clunk going into drive ways or speed bumps.
