clunk going over small step
GeoRoss - I had similar experience when I go over the speed bump at Shopping mall, :flipoff2: and the edge of the driveway.
I agree with what Dough said in the post #3. I just did my entire front repack today, and no more clunk/rubbing sound on speed bump. :cheers:
When was your last repack?
It is not the front, it is the rear. Axle service was done 08/2005, ~15k ago.
I had very similar symptoms after I had a lift installed and found alittle play in the bushing set on the top of the plate bracket for the rear ps shock. I could replicate the sound by rocking back and fourth on the rear bumper. Just a thought and good luck...
My "clunk" in the rear turned out to be a loose shock bolt which was only heard over small bumps.
Tightened it down, no more clunk.
Thanks for bring this thread back to my attention GeoRoss. This was never resolved and continues to bug me. I had written this off the a little axle lateral play but I'm now not so sure. I'm going to recheck all the bushings again and see if I can track it down.
let me know what you find but I'm pretty sure mine's from the front not the rear.
R
R
No problem,
After checking every bolt to the suspension system today in preparation for Moab, the only thing I found was that the muffler rubber bushing was entirely torn in half. Lucky for me, the rubber bushing is exactly like the one on the resonator that I removed. To bad for me that did not get rid of the noise.
I suspect that it is one of the 14 year old bushings. No more time for looking right now. When I get back I'll try removing the sway bars and see if I can remove them from the running.
The thing that sucks is I cannot get it make the noise in the driveway by rocking. Oh well.
I have a sound and feeling in the DS floorboard. It sounds like and feels like a All Terrain tire rubbing on a fender, unfortunately I'm running regular street rubber. I've checked for rubbing and I'm not seeing anything.
This may be the answer to my question, but please confirm or deny, I was informed by Firestone during an alignment, that the wheel bearings are going out. The reason I ask the question: I don't want to order some of the parts from C-dan, then tear apart the front end and need to order more parts, leaving the LX down for a couple weeks.
thanks, hopefully this isn't a hijack!
Not sure if this is relevant or not but I had something similar for almost 6 months before I figured it out. I had just put in a new Hi-Lift Jack on the back of my rig and had everything tightened down. Everytime I would go across a speed bump or ruts across a road I would hear a bump bump bump more or less and it would drive me crazy. Never thought it would have been the hi-lift jack in the back moving around in it's cradle. See Signature. I put in a rubber flooring for the jack on the cradle and around the lips of the cradle. Now silent as she was before ;p Might be worth looking there to if you have a Slee bumper and jack.
Only other thing you might check is the shocks. One of mine was a little loose, and would move and make a clunking sound under the right conditions... usually the combination of a slow turn and a small bump or seam in the road.
:beer:
Rookie2
