Clogged catalytic converter... options?
Simi Valley, CA
I have been experiencing a loss of power, especially under load (going up even small hills). The engine will rev and downshift, but the vehicle won't go anywhere. Took it to a local shop that specializes in LC's (K&H Auto Imports in Canoga Park, CA), and they confirmed it's a clogged catalytic converter/ converters.
Since mine is a 96, I have the one behind the other style, and was told by a local exhaust shop that one or both may need replacement ($225 for one & $450 for both). Was wondering if I should take this opportunity to do any of the following:
1) Get high flow cats? (the guy at one exhaust shop said he can only install what the book tells him to (Catco or Magnaflow, that is called out for my vehicle), and high flow cats will not give me any more power.
2) Get a single larger cat? Any benefits of this? Even though this is technically not legal, I am told that it will still pass the smog test.
3) If a single cat is okay, redo the piping to have it on the inside of the frame... similar to the 91-94 layout? If I do this, assuming that I will have to add some heat shields?
I do have sliders with the protection for the cats, but was thinking I could cut-off/modify that section for better clearance on the trails (as I only plan on doing a 2.5" lift).
Getting even a little more power/flow would be nice, and I just want to do this once. I don't intend on changing the stock muffler (should I) as don't want exhaust drone noises on the hwy.
You have a CA vehicle, you really don't have an option. Go with the Flowmaster and call it a day. It's a two piece replacement. Rear cat and front cat which includes the Y-pipe. It's about an hours worth of work using common hand tools.
Would you be able to post a link to the one you are referring to? The only one I found was this, which is a single cat with no y-pipe:
Flowmaster Catalytic Converter Catalytic Converter Cadillac | DiscountCatalyticConverters
Thanks again guys!
Have you removed the cats and inspected? You can try and clean them with citric acid oxalic acid. It cleaned up my fouled but not plugged cats.
No, not removed yet, but my cruiser has @195k miles and the original cat is 20 years old, so just going to go with an upgrade... hopefully for another 20! :)
I second the Magnaflow cats if you decide to replace, I put the front one/y-pipe on my '94 and it's well worth the money. I just skipped the second cat and had custom exhaust bent up since my county (at the time) only required a visual inspection on emissions components and the one cat was good enough to pass that. :hillbilly:
Cleaning them might work (CRC Guaranteed to Pass) if you wanna give that a shot for a quick fix. It has worked for me before on vehicles with a cat performance code/ CEL. Like Landtoy said they could be melted inside and then you'd just be wasting your time and money trying to clean them. It's only ten bucks at Wally World and an hour though so why not try that first? Pour the stuff in a quarter tank of fuel and go romp it on the highway for a while. :steer:
How did they decide it was clogged? Did they take out the O2 sensor and use a gauge to read back pressure? Did they pull it apart to do a visual to see them clogged? Question is why they got clogged and will happen it again to the new one. If, as mentioned above, they melted, you have a problem upstream too.
You say 2 things in your posts. First, the shop says it clogged, then you say you just want to upgrade. You should measure the back pressure for real numbers.
Good question. I totally agree with you... I wouldn't want my new cat/exhaust system to get clogged either! The shop said they checked the back pressure at the EGR valve, and said it should read @2-3psi at most, but pegged out the test gauge which had a max reading of 15psi. Does that make sense?
The other unknown is that the vehicle was quite neglected when I got it. The HG was replaced by the PO, so not sure what caused that repair, and how the HG failure may/may not have affected the cats. Even though it's an on-going project to baseline it, I'm not sure what other abuse it may have seen over the years. Since buying it, I have driven only @5k miles.
The weird thing is that the car is not throwing any codes at the moment. I did have a P0402 code, but I fixed that when I bypassed the clogged tube going through the intake. I then got a P0136 code (Powertrain. O2 sensor circuit malfunction (bank 1 sensor 2), and have reset that twice, but it hasn't come back in the last couple of weeks.
Has anyone used seafoam in the gas tank and/or through the vacuum line that's connected to the brake booster, in an attempt to clean out the cats?
Cleaning cats with an additive will not remove years of ZDDP, ash and other buildup of combustion byproducts.
It may remove any loose material.
Here is a google search of citric acid acallic acid cat - Google Search
I don't remember which article or forum I went off of but there is a ton of info about it.
My cats with 417,000 mi were almost 98% free from any clogs in the screen like material in the cat. They were heavily coated though.
Cat Cleaning Citric & Oxalic Acid. CO Emissions
I am sure that with my miles, amount of high ZDDP oil that has burned through and lately burned at a high rate of consumption, a second or third bath of the acids may of cleaned more buildup from them.
Clean them is not that hard but very time consuming. I didn't have a way to flow the solution so I just agitated the solution every so often. A constant flow would surely be better then my method. If I still have the 80 next time emissions/license plates are due, I will do more testing with the solution as I still have plenty of the acids left over.
If you are cheap (like me) and/or poor (like me) its worth the effort. If you are one to get in a hurry and not follow directions AND like to "female dog" about how it doesn't or can't work, then don't waist your time. The data is from Europe, and was tested on diesel vehicles that have catalytic converters. The only thing I have in common with a diesel is the oil, I use Rotella T6 diesel motor oil. It has higher concentrations of ZDDP. Note, if you cat is worn out then nothing will replate or replace the lost catalytic from the screen like material in the cat. I would bet money (if I had any) the cats don't wear out, they just foul out from years of buildup. Other wise, there would not be such a demand for used cats, unless the platinum is under the coating the causes the catalyst???
get what's smog legal in Cali.
regardless of what you try, the 80 is simply a brick on wheels. you will not get any more appreciable speed nor power by messing with your cats...you will only gain the potential of additional headaches down the road if and likely when someone dings you on a visual inspection of your cats.
why are you even considering doing anything else?
if you want to go faster buy a Lexus GS F...
Wow... Almost $800!! Is it worth the time/effort to try and remove/weld the cats off and try and clean them? I have read of people using things like seafoam through the brake booster vacuum line or drill a small hole in front of the front cat, and spray carb cleaner in (I know this is not safe, and I have not done it, so a bit hesitant to do it). Has anyone with clogged cats tried and been successful cleaning them? My vehicle has close to 195k miles on it.
If you guys feel the cleaning may not work (considering it will probably cost me @ $100 to have a shop remove and re-install the cats), then I have a quote from a local muffler shop to replace both cats (CA legal) for $450 out the door, which I guess would be by least expensive option.
I replaced both mine with magnaflow. Old ones weren't plugged, but at 300k miles, had lost all their exhaust scrubbing mojo. Emissions improved dramatically, power did not change... but again, mine weren't plugged.
Excuse my ignorance on this subject and California, but is there a reason Walker's universal calcat won't work? I think they run like $115 ish on summit. Just curious, I'm looking at walker universal cats for my swap and when researching found the Colorado referee thought highly of them....
One option would be to stop using diesel oil?
There is 48 state legal cats (excludes CA & NY), so the one you are talking about should be fine for CO. I suppose owners in CA & NY have to fork out extra $$ for cats that are approved only for those two states. Would it be correct to assume that these are more restrictive??
