Going to try the safety wire. I tried a thicker guage of wire with no luck . Tried tapping it in with a hammer. Started to bend that little nozzle.Mine was mostly gunked up from inside the TB bore. I went in there with some safety wire and TB cleaner. Then poked at it from both sides, fed TB cleaner through it at the end.
no, come at it from inside the TB.Going to try the safety wire. I tried a thicker guage of wire with no luck . Tried tapping it in with a hammer. Started to bend that little nozzle.
I looked inside didn't see where it came out from inside. I'll take a look again thanks manno, come at it from inside the TB.
All I have is a dinky water hose.pressure washer?
there are 3 very tiny holes on the inside of the TB right at the throttle plate when closed. I think the middle one is in front of the plate and the other two are right behind it. They are super tiny and easy to miss.I looked inside didn't see where it came out from inside. I'll take a look again thanks man
Thanks B16/ Rifleman. I found the 3 little holes. You were not kidding when you said that they were small. I ended up using some carb cleaner, paper clip, and a thumb rack to clean them. Would have prob been easier with the wire. Now all that's left to do is put everything back together. Hopefully those cables cooperate.there are 3 very tiny holes on the inside of the TB right at the throttle plate when closed. I think the middle one is in front of the plate and the other two are right behind it. They are super tiny and easy to miss.
