Clean Pair valve?
How have you determined when the PAIR valve is working or not?
The rig will drive around normally for some time without issue. As in like a day. Then at times it will idle really rough, so I'm thinking it's sticking. If I disconnect the pair valve and block it off completely I have no issues whatsoever and the intermittent rough idle does not happen.
I took one apart a couple years ago. There are a couple reeds inside. Mine looked clean. I don't really understand how that system works. Isn't it a substitute for a belt driven air pump?
It's supposed to allow fresh air from the intake to be sucked into the exhaust, mainly during deceleration I think. By allowing air into the exhaust any unburned fuel is burned.
