Circuit Tester / Test Light
Tulsa, OK
I am looking for a good test light, built with an LED instead of a normal bulb.
I have read so many reviews where the bulb would burn out, rendering the tool useless. I figured an LED would be much more durable.
This Craftsman looks great, but it's not LED.
An LED will draw very little current, and only will light in one direction. I've got one, but don't like to use it. It's a cheap POS that came with a trailer wire harness, IIRC. A Google search shows some available.
What do you mean by "only in one direction" ?
I thought the leads of the test light were reversible. It doesn't matter which one goes on the positive and which goes to the ground. Is that correct ?
Celica XX a LED is a diode current only goes one way with a diode if you try/accidentally hook the neg of the tester to a positive of the circuit it will not light giving you a false reading. A light balb tester works both ways
I've seen the tester on extreme 4x4 to looks like a good unit. I asked my wife to get me one for Christmas.
Chris
I've had a test light for several years. The light bulb still works. If you're really concerned about durability/redundancy, just buy another one or keep a VOM as a backup.
LED light is a bad idea IMHO.
When I searched I did see some that have multiple LED's, that will tell you if you have the leads reversed and other features. It depends on what you're going to do with it. A light bulb will draw some current, so it will indicate bad connections and low voltage, which an LED can't do. At least, not a straight, simple LED- like I said, they have added circuit boards and chips and whatnot to add features. The beauty of a test light is its simplicity, IMO.
A normal filament bulb is a good thing. You need to put a resistive load on the circuit you are testing to see if you have a bad connection. If the bulb is dim, you know you have a bad connection somewhere upstream toward the battery.
Just saw this on Xteme 4x4 TV show today, maybe it's what you're looking for?
Tools for the Automotive Technician
I was a Audio/Security Installer for close to 10 years before changing careers....
I have always, and still use the Power Probe. I have the simple LED/12volt/Negative version and have never had a problem with it. It's my 2nd one because my first one went bad after a few years but I did no hesitate to get another one. They are GREAT for working on cars/bikes/anything 12v-24v.
Thats my .02. :cheers:
